11-13-2012 06:36 AM - edited 03-07-2019 10:01 AM
We have a core switch Catalyst 3550-24-PWR
Connected are 2 Catalyst 2960 PoE-24 and one Catalyst 2950-24
3550 together 2960 works well
2960 together 2950 works well
3550 connected with 2950 refuse to establish connection. Port goes down immediately.
Example
3550 Fe0/19+Fe0/20 -> 2960 G0/1+G0/2 status OK
3550 Fe0/21+Fe0/22 -> 2960 G0/1+G0/2 status OK
2960 Fe0/12 -> 2950 Fe0/24 status OK
3550 Fe0/8 -> 2950 Fe0/24 status down
Anyone have an idea what should cause this behavior? I'm hopeless.
All the ports between switches are configured as Trunk (VLAN ALL)
Solved! Go to Solution.
11-13-2012 06:53 AM
Have you tried a cross over cable between the 3550 and 2950?
11-13-2012 06:51 AM
Have you hardcoded both sides for speed/duplex?
11-13-2012 07:09 AM
Nope, as all ports are 10/100, but I will check and let you know.
11-13-2012 06:53 AM
11-13-2012 07:10 AM
I don't, cause 2960 and 2950 works together on straight cable. I can try of course.
11-13-2012 09:00 AM
Reza is correct , the 2960's have auto mdix capability so it doesn't matter if a crossover or straight thru is used as long as the port is set as auto. Neither the 3550 or the 2950 have this capability so the cable "must" be a crossover to come active.
11-13-2012 10:12 AM
Roman,
Reza and Glen are correct, and it didn't hit me that you weren't getting a physical connection at all. Use a crossover cable and you should be set.
HTH,
John
11-14-2012 12:37 AM
Guys,
thanks for your suggestions, I will try the cross cable ASAP I will find some in the box.
Strange is, when I execute "reload" the switch is connected for a few seconds after soft restart, or at least the led is green. That's why I did suspect some feature on 3550.
btw, so far I remember, the 2950 was always connected to router directly, so was 3550 as well. This problem start after upgrade to 2950 to 2960.
Once tested, I will confirm if it works.
Thanks again to all of You.
Roman
11-14-2012 06:35 AM
I can confirm CROSS OVER cable solved the issue.
Thank's to all of you once again.
Roman
