Cisco 867VAE no console comms after reset
mspellman1
Hello Everyone. Please help if you possibly can!
I have a Cisco 867VAE that I can no longer communicate with via the console port.
This started after a hardware reset.
How can I re-establish communications.
Is there anything that can be done?
Mike
michael o'nan
Level 4
Level 4
while console into the router can you power cycle and see if anything is displayed?
Hello Michael  yes  I can see the router reboot.
Once completed I can not type anything in to the router.
Mike
Can you add a capture or copy the boot ? did you try to enter in rommon mode?
Regards!
