Cisco 871 and C2960 routing between vlans.
derrick
I have an 871 wireless router (c870-advipservicesk9-m version 15.1) and the c2960 switch (c2960-lanbasek9-m version 12.2). I was wondering if i can use the 871 to route between vlans on the c2960. I need to have 7 vlans setup on the network but the 871 only supports 4 vlans in its database. I know I can create more than 4 vlans on c2960's database but I don't how or if it's even possible to route between those vlans using the 871.
21 Replies 21
Thanks for that.
Hi Lei,
Just tried IOS versions 12.4(15)XY5, 12.4(11)XW10, and 12.4(4)XC7 and all three 12.4 will support 2 VLANs.
It looks like only 12.3 will support 10 VLANs.  Too bad.
Hi Leo,
Thanks for testing it out!
Thanks Lei.
Hey Leo,
Do you know if version 12.3 supports DMVPN? I'm not able to find that it does.
12.3 supports DMVPN. You can check it through the following link:
www.cisco.com/go/fn
NT
derrick
THANK YOU ALL!!!
You've been very helpful! I will look into downgrading to 12.3.
