Cisco 871w simple home router setup issues... [Unable to ping internet]
Hey,
I have a Cisco 871w and i am trying to confiure it as a simple home router at first and then start adding functionality such as a DMZ and a IPSEC vpn gateway.
I have a basic understanding of cisco networking as i did a cisco module at university that was supposed to leat to the CCNA qulification.. however i have not taken the exam or touched cisco gear in about a year so i am very rusty at the moment...
I have attempted to setup a realy basic config on the device that should provide dhcp to hosts attached the the 4 port internal switch and route traffic out the wan interface [fe4] and onto the internet [via my homehub]
The setup is shown bellow
[INTERNET]----86.144.219.57-[HomeHub]-192.168.1.1/24---------192.168.1.3/24-[Cisco 871w]-192.168.2.200/24-------
currently i am haveing problems pinging the internet from the cisco router at all... i have printed the config, routeing table and the output of some pings bellow...
any help here would be good... thank you
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Router>ping
Router>ping 86.144.219.57
Sending 5, 100-byte ICMP Echos to 86.144.219.57, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/4 ms
Router>ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C*   192.168.1.0/24 is directly connected, FastEthernet4
S*   0.0.0.0/0 is directly connected, FastEthernet4
Router#
Router(config)#do show run
Building configuration...
Current configuration : 1645 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool users
   import all
   network 192.168.2.0 255.255.255.0
   domain-name users.das-haus-online.co.uk
   dns-server 208.67.222.222 208.67.220.220 192.168.1.1
   default-router 192.168.2.200
ip cef
no ip domain lookup
archive
log config
  hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.1.3 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface Dialer0
no ip address
no cdp enable
interface BVI1
ip address 192.168.2.200 255.255.255.0
ip nat inside
ip default-gateway 192.168.1.3
ip default-network 192.168.1.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip http server
no ip http secure-server
ip nat inside source list 7 interface FastEthernet4 overload
access-list 7 permit 192.168.2.0 0.0.0.255
no cdp run
control-plane
bridge 1 protocol dec
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
cadet alain
Could you do this:
no ip default-gateway 192.168.1.3
no ip default-network 192.168.1.0
no ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 0.0.0.0 0.0.0.0192.168.1.1
Regards.
Alain
ahhh perfect!!
Thank you Alain!
It is now running well
I will remember that the route needs to be the end roter and not the interface!!
Thank you again!!
Router(config)#do ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/40/41 ms
Router(config)#
creature@sparky:~/$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_req=1 ttl=48 time=38.5 ms
64 bytes from 8.8.8.8: icmp_req=2 ttl=48 time=38.8 ms
64 bytes from 8.8.8.8: icmp_req=3 ttl=48 time=38.5 ms
64 bytes from 8.8.8.8: icmp_req=4 ttl=48 time=38.9 ms
64 bytes from 8.8.8.8: icmp_req=5 ttl=48 time=38.7 ms
^C
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4001ms
rtt min/avg/max/mdev = 38.514/38.718/38.974/0.279 ms
