Cisco 877 Config static routing
eric
dear all,
i am trying to setup my router to work as below can someone advise how do i go about?
Cisco 877
Fa0(Vlan2) ---> WAN1 LINK Router
fa1(Vlan1) ---> Local Network{192.168.210.x}
fa2(Vlan3) ---> WAN2 LINK Router
fa3(vlan4) ---> WAN3 LINK Router
All traffic should be routed to WAN1 by default.
Except for destination ip 10.172.111.11 should be routed to WAN2
and destination ip 10.20.11.22 should be routed to WAN3
For Eg... a host @ Vlan1 do a Ping to 10.20.11.22 it should be routed to WAN3
and if  ping to other address it will route to WAN1
5 Replies 5
eric
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.210.1 192.168.210.50
ip dhcp pool LAN
   import all
   network 192.168.210.0 255.255.255.0
   default-router 192.168.210.1
   dns-server 165.21.83.88 8.8.8.8
   lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip name-server 165.21.83.88
ip name-server 8.8.8.8
username admin privilege
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ----- address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode transport
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA1
archive
log config
  hidekeys
interface Tunnel0
bandwidth 1000
ip address 10.10.10.210 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication DMVPN_NW
ip nhrp map multicast -----
ip nhrp map 10.10.10.1 ----
ip nhrp map 10.10.10.2 ---
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 10.10.10.1
ip nhrp nhs 10.10.10.2
ip nhrp registration no-unique
ip tcp adjust-mss 1360
delay 1000
tunnel source Vlan2
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile CiscoCP_Profile1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
switchport access vlan 3
interface FastEthernet3
switchport access vlan 4
interface Vlan1
description LocalLan
ip address 192.168.210.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
description **wAN1***
ip address dhcp
ip nat outside
interface Vlan3
description **wAN2***
ip address dhcp
ip nat outside
interface Vlan4
description **WAN3***
ip address dhcp
ip nat outside
interface Dialer0
no ip address
shutdown
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Vlan2
ip route 10.20.11.2 255.255.255.255 vlan4
ip route 10.172.111.0 255.255.255.0 Vlan3
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface Vlan2 overload
access-list 1 permit 192.168.210.0 0.0.0.255
no cdp run
control-plane
any kind soul around to help? tks!
Hello Eric,
It seems to me that your configuration is almost correct. However, it is not appropriate to define static routes via exit multiaccess interfaces such as Ethernet without specifying the next hop IP address. This may, under circumstances, not work at all, or it may result in huge ARP traffic and overgrown ARP tables.
The slight "gotcha" in your case is caused by the use of DHCP on all your WAN interfaces. However, in that case, you may tell the router to use the DHCP-assigned gateway on the appropriate interface as the next hop IP address in that specific static route. So I suggest using the following modification:
no ip route 0.0.0.0 0.0.0.0 Vlan2
no ip route 10.20.11.2 255.255.255.255 vlan4
no ip route 10.172.111.0 255.255.255.0 Vlan3
ip route 0.0.0.0 0.0.0.0 vlan2 dhcp
ip route 10.20.11.2 255.255.255.255 vlan4 dhcp
ip route 10.172.111.11 255.255.255.255 vlan3 dhcp
Note that I have added the dhcp keyword into each static route, forcing the router to use the appropriate DHCP-obtained gateway on the particular interface for the next hop of this route. Also, I have corrected the route 10.172.111.0/24 into 10.172.111.11/32 per your original description (you did not talk about the entire network, just about a single IP address).
Can you test this out and let me know if it worked?
Best regards,
Peter
Hi Peter.
I have done as u mention..
From the Cisco 877 router i am able to ping to 10.20.11.2 and 10.172.111.11
But from my host from vlan1 eg. 192.168.210.xx is unable to reach the 2 addresses
do i need to set any ACL?
Sorry..
I add this 2 ACL before my router is able to ping.. but the users in vlan1 is still unable to ping
access-list 101 permit ip host 10.20.11.2 192.168.210.0 0.0.0.255
access-list 101 permit ip host 10.172.111.11 192.168.210.0 0.0.0.255
Hello Eric,
The NAT configuration in your case will have to be modified, so that packets exiting a particular WAN interface are NATted to the interface's particular IP address. Currently, they are all NATted to the Vlan2 interface IP address which is clearly incorrect if the packets are sent out the interface Vlan3 or Vlan4.
Please do not modify your ACL - put it back to the state it was originally. However, add these lines to your configuration:
no ip nat inside source list 1 interface Vlan2 overload
route-map Vlan2 permit 10
  match ip address 1
  match interface Vlan2
route-map Vlan3 permit 10
  match ip address 1
  match interface Vlan3
route-map Vlan4 permit 10
  match ip address 1
  match interface Vlan4
ip nat inside source route-map Vlan2 interface Vlan2 overload
ip nat inside source route-map Vlan3 interface Vlan3 overload
ip nat inside source route-map Vlan4 interface Vlan4 overload
Please give it a try and let us know if it worked for you. Thanks!
Best regards,
Peter
