Cross Stack Etherchannel implementation steps ?
AndrisK2006
Community Member
I want Implement Cross Stack Etherchannel (cisco Catalyst 3750) for high availability. What is right implementation steps / order?
This is real production installation so I would like not to have any downtimes during / after implementation.
Core1-1
Gi1/0/24
interface GigabitEthernet1/0/24
description trunk-between-cores
switchport mode trunk
no mdix auto
no cdp enable
end
Core2-1
no mdix auto
end
Best regards,
Andris
7 Replies 7
Reza Sharifi
You config should work just fine.  You also need to add the second physical port to the portchannel and create the portchannel itself.  You will need an outage window to do this as when you move the existing link to a portchannle, there will be short down time.  don't forget to specify LACP or PAGP.  A good practice is to shut down the physical ports first than add them to the portchannel and than "no sh" on the portchannel to bring up the portchannel and the physical links.
Ok, that mean I need schedule short outage for my production systems.
Johnny.Stevenson
Community Member
Which IOS release are you using? Cross stack LACP only works after a certain 12.x release. Other than that, configure in the usual way for LACP. It will be disruptive though, the interfaces will bounce.
Sent from Cisco Technical Support Android App
Both Stacks are running 12.2(35)SE2 IOS version.
Johnny.Stevenson
Community Member
Interface g1/0/X
Swithport mode trunk
Swithport trunk allowed vlans all
Channel group 1 mode on
Repeat for other interfaces to be added to the etherchannel.
Interface Po1
Leo Laohoo
How far are the two stacks from each other?
Not far , approximately 50 meters.
