Cisco 881W vlan routing latency/packet loss
markgraham
Hi All,
I am having and issue with a Cisco 881W and high ping times between devices on different vlans as well as packet loss.
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M8
I have physically plugged in two machines to the router and tried to copy a file between the devices on different vlans and its extremely slow however if they are on the same vlan it works fine. Ping times fluctuate from 4 - 7ms between machines.
Is this a known issue with this device and that particular firmware? or have I done something wrong?
Attached is the config file.
Thanks in advance.
markgraham
This has been resolved.
It was an issue with a NIC
