HSRP group question
David Niemann
Level 3
Level 3
If you have multiples VLAN SVIs configured with the same HSRP group, does changing the priority on one SVI to failover to another router cause all the SVIs in that group to switch to the other router or do the individual priority settings keep that from happening?
Reza Sharifi
Never tested that but I think since the priority is configured after the group id if you change the priority it will take effect for all the SVIs
 standby 1 priority 150
I would think that since you configure the priority in interface config mode (not in global config) that it would affect only the SVI on which you configure it.
Rick
Rick
