Cisco 887 License advipservices NOT installed
Hello all, please could you someone help me about this issue (critical for me...)
My company bought the PAK for the advanced IP services feature. Actually I'm using the Evaluation type.
Using the Cisco License Portal I got by email the new license.lic file but when I try to install on the router I don't get the message "successfull installed..."
and the advipservices is still in evaluation mode.
TSIH401-b#sh license
Index 1 Feature: advipservices
        Period left: 1  week  3  days
        Period Used: 7  weeks 0  day
        License Type: EvalRightToUse
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
Index 2 Feature: advsecurity
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Priority: Medium
Index 3 Feature: ios-ips-update
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: WAAS_Express
Index 5 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
TSIH401-b# lice install flash:FCZ162092G1_20120824021311032.lic
Installing licenses from "flash:FCZ162092G1_20120824021311032.lic"
Installing...Feature:advsecurity...Failed:
% Error: Duplicate license
0/1 licenses were successfully installed
1/1 licenses were existing licenses
0/1 licenses were failed to install
The advsecurity is already installed permanent, so It's right the duplicated, but it seems that the new license file is not able to overwrite the evaluation feature.
Many tks in advance for your support.
regards
Matteo
Eugene Khabarov
Level 7
Level 7
Hi! Try to disable advipservices license first. Something like this:
license boot module c880 technology-package advipservices disable
Syed Taukir
you can try using the command
Router(config)#license boot module c880-advipserveice
Syed
paolo bevilacqua
reload router.
