Cisco 887VA
HAMZA NISAR
Hello, I'm new in cisco router configurations. I have Cisco 887VA model router i'm trying to add ip address on ports but it is showing that % IP addresses may not be configured on L2 links. I'm also trying to convert ports in L3 but when in use no switchport it's coming like '' % Incomplete command'' is there any way to add ip address on ports. i want to do nating outside and inside.
Thanks in advance.
thank you georg now it's working i understand but you helped me to do this. but now i've one more counfusion i've mad two vlans
vlan 10: 192.168.100.1
vlan 20: 192.168.1.1
Thing is that when i ping from vlan 10 to 20 it's pinging but i've not performed ip routing command in router then how different subnets are pinging.
12 Replies 12
balaji.bandi
as i remember only 2 ports on that router act as WAN / Layer3 ports 0 or 1 as i remmeber
you can do below way if you looking to use that ports
vlan 10
interface fas 0
switchport access vlan 10
no shut
interface vlan 10
ip address x.x.x.x 25.25.255.X
no shutdown
still have issue post below interface from router:
show version
show ip interface brief
show run
below guide help you :
https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_010.html
BB
Hi i.ve tried but not working. below are details.
Router>show version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 21:03 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Router uptime is 28 minutes
System restarted at 06:28:45 UTC Wed Feb 6 2036
System image file is "flash:c880data-universalk9-mz.151-4.M5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 887VA (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID.....
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
License Information for 'c880-data'
License Level: advsecurity Type: Permanent
Next reboot license Level: advsecurity
Show IP int bri
Router>show ip int bri
ATM0 unassigned YES unset administratively down down
Ethernet0 unassigned YES unset administratively down down
FastEthernet0 unassigned YES unset down down
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset down down
FastEthernet3 unassigned YES unset down down
Vlan1 unassigned YES unset down down
Router>
show run
Router#show run
Building configuration...
Current configuration : 958 bytes
! Last configuration change at 06:56:44 UTC Wed Feb 6 2036
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
what have you tried ? What does not work ? Post the command sequence you are entering and the resulting error message.
Hi gerog, firstly don't get angry i'm just a beginner.
int
CiscoR1(config)#interface f
CiscoR1(config)#interface fastEthernet 0
CiscoR1(config-if)#ip add
CiscoR1(config-if)#ip address 192.168.1.2 255.255.255.0
the 4 FastEthernet interfaces are layer 2 only. Does this work ?
CiscoR1(config-if)#switchport access vlan 10
CiscoR1(config-if)#exit
CiscoR1(config)#interface Vlan 10
CiscoR1(config-if)#ip address 192.168.10.1 255.255.255.0
yes this is working but only with one interface i want to assign ip to 2 interface apart from that is this compulsory to make vlan? is there no any other way to assign ip to ports?
what do you mean by 'it works only with one interface' ? It is difficult to follow what you are doing...post a screenshot of the command sequence you are entering...
Router(config)#interface vl
Router(config)#interface vlan 10
Router(config-if)#ip add
Router(config-if)#ip address
Feb 6 09:33:34.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed stanterface vlan 10
Router(config-if)#ip address 192.168.1.2 255.255.255.0
Router(config-if)#ip na
Router(config-if)#ip nat ou
Router(config-if)#ip nat outside
Feb 6 09:34:04.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
Router(config-if)#no n
NVI0 unassigned NO unset up up
Vlan10 192.168.1.2 YES manual down down
Router(config)#int
Router(config)#interface f
Router(config)#interface fastEthernet 1
Router(config-if)#s
Router(config-if)#sw
Router(config-if)#switchport mo
Router(config-if)#switchport mode a
Router(config-if)#switchport mode access
Router(config-if)#switchport a
Router(config-if)#switchport access vl
Router(config-if)#switchport access vlan 20
Router(config-if)#exit
Router(config)#int
Router(config)#interface vlan 20
Feb 6 09:35:06.279: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed
Router(config-if)#ip address 192.168.100.1 255.255.255.0
Router(config-if)#ip nat in
Router(config-if)#ip nat inside
Router(config-if)#no sh
Router(config-if)#no shutdown
you get no errors, you are typing the correct commands. Where is the problem, what do you want to accomplish ?
you got it ! It is working...
IP routing is enabled by default, if it is disabled, you would see 'no ip routing' in the running configuration. You won't see 'ip routing'...which means it is enabled.
Georg you helped me. thank you. I've one more thing to ask what is VDSL and atm0, i not understand this what's this work.
