11-11-2011 06:51 AM - edited 03-07-2019 03:20 AM
I am currently configuring (10) Cisco 891 routers for our remote users. For some reason, I have always had issues getting the wireless running correctly. I currently CAN connect to the Guest SSID but I do not recieve an IP address, just self assigned. Here's the config:
Router Side:
Current configuration : 8341 bytes
! Last configuration change at 13:21:43 UTC Tue Jul 26 2011
! NVRAM config last updated at 13:21:45 UTC Tue Jul 26 2011
version 15.0
hostname Test
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa group server radius dot1x
server-private 172.20.0.157 auth-port 1812 acct-port 1813 key NBR3M0tE
aaa authentication dot1x default group dot1x
aaa authorization network default group dot1x
aaa session-id common
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-3622028497
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3622028497
revocation-check none
rsakeypair TP-self-signed-3622028497
crypto pki certificate chain TP-self-signed-3622028497
certificate self-signed 02
30820250 308201B9 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33363232 30323834 3937301E 170D3131 30373236 31323437
34345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36323230
32383439 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AF9F 1707E4A8 9B6C5C65 4A15800B F1CF9C05 5C5F7D42 EFB9F095 B13E96DD
1863D989 9753094A EBBB5D0C 750CBA5B D1C317A8 A067546D 412F372C E329CC78
9A391BB0 4F937155 32E13481 64554EFC 1E555713 DFFDAD1D B564648E 35812437
B64E1B84 0422DC42 DC97F02C 0006181B F1DC9273 9080509C E66CBB22 6245669C
7E850203 010001A3 78307630 0F060355 1D130101 FF040530 030101FF 30230603
551D1104 1C301A82 1864616E 70696E65 61752E79 6F757264 6F6D6169 6E2E636F
6D301F06 03551D23 04183016 8014516F 3F5FD8BB 5CC066C8 8C80EAC5 6CB71DEC
842E301D 0603551D 0E041604 14516F3F 5FD8BB5C C066C88C 80EAC56C B71DEC84
2E300D06 092A8648 86F70D01 01040500 03818100 0DA9DD3C 6C017FA1 9A510968
58393ECB D4C3AEEA 514EEA78 E1063542 D7175B51 1F54EC6E AECE0E89 0945A7A0
D3AFD63B 0698F3FD 598B96EC F42C252E B3D203C0 E6107514 C7BDD087 F5E1599D
8D5F6F13 8BFD5F19 E83495BE 439CC3FE 79BF6006 18755D18 A1BE26A7 F4CDCA1C
F425B23D DB4205CE 6DDCC355 4F243BD5 83BD2853
quit
ip source-route
ip dhcp excluded-address 192.168.55.1
ip dhcp excluded-address 192.168.55.2
ip dhcp excluded-address 192.168.33.1
ip dhcp pool NBGuest
import all
network 192.168.33.0 255.255.255.0
default-router 192.168.33.1
ip dhcp pool NBCorporate
import all
network 192.168.55.0 255.255.255.0
default-router 192.168.55.1
option 150 ip 172.19.0.240
dns-server 172.20.0.157
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip inspect name fwconf tcp
ip inspect name fwconf http
ip inspect name fwconf smtp
ip inspect name fwconf udp
no ipv6 cef
license udi pid CISCO891W-AGN-A-K9 sn FTX15278587
no username cisco
username admin privilege 15 secret 0 NBR3m0t3
class-map match-any voice-control
match ip precedence 3
match ip dscp af31
match ip dscp cs3
class-map match-any voice-bearer
match access-group 101
match ip dscp ef
match ip precedence 5
policy-map llq
class voice-bearer
priority 640
class voice-control
bandwidth 96
class class-default
fair-queue
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key NBR3m0t3 address 204.126.80.51
crypto ipsec transform-set VPN-1 esp-3des esp-md5-hmac
crypto map VPN-TRANS 1 ipsec-isakmp
set peer 204.126.80.51
set transform-set VPN-1
match address 110
interface FastEthernet0
interface FastEthernet1
switchport voice vlan 11
dot1x pae authenticator
dot1x port-control auto
dot1x max-req 1
dot1x reauthentication
dot1x guest-vlan 20
spanning-tree portfast
interface FastEthernet2
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet3
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet4
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet5
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet6
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet7
dot1x max-req 1
dot1x guest-vlan 20
interface FastEthernet8
description Outside
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
arp timeout 0
service-policy output llq
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface Vlan1
description Data VLAN
ip address 192.168.55.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip pim sparse-dense-mode
ip nat inside
ip inspect fwconf in
ip tcp adjust-mss 1452
no autostate
interface Vlan11
description Voice VLAN
ip unnumbered Vlan1
ip access-group allow_skinny in
no autostate
interface Vlan20
description Guest VLAN
ip address 192.168.33.1 255.255.255.0
ip nat inside
no autostate
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list nonat interface FastEthernet8 overload
ip access-list extended allow_skinny
permit udp any any range bootps bootpc
permit udp any any eq domain
permit udp any any eq tftp
permit tcp any any eq 2000
permit udp any any eq 5445
permit udp any any range 2326 2373
permit udp any any range 16384 32764
permit ip 192.168.55.0 0.0.0.255 172.19.0.0 0.0.255.255
permit ip 192.168.55.0 0.0.0.255 172.20.0.0 0.0.255.255
permit ip 192.168.55.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip any any log
ip access-list extended nonat
deny ip 192.168.55.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip 192.168.55.0 0.0.0.255 172.19.0.0 0.0.255.255
deny ip 192.168.55.0 0.0.0.255 172.20.0.0 0.0.255.255
deny ip 192.168.55.0 0.0.0.255 172.29.0.0 0.0.255.255
deny ip 192.168.55.0 0.0.0.255 172.30.0.0 0.0.255.255
permit ip 192.168.55.0 0.0.0.255 any
permit ip 192.168.33.0 0.0.0.255 any
ip radius source-interface Vlan1
access-list 101 permit udp any any range 16384 32000
access-list 101 permit tcp any any eq 1720
access-list 110 permit ip 192.168.55.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 110 permit ip 192.168.55.0 0.0.0.255 172.19.0.0 0.0.255.255
access-list 110 permit ip 192.168.55.0 0.0.0.255 172.20.0.0 0.0.255.255
access-list 110 permit ip 192.168.55.0 0.0.0.255 172.29.0.0 0.0.255.255
access-list 110 permit ip 192.168.55.0 0.0.0.255 172.30.0.0 0.0.255.255
access-list 110 deny ip any any
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler max-task-time 5000
end
Wireless AP:
Building configuration...
Current configuration : 2835 bytes
version 12.4
no service pad
hostname ap.danpineau
aaa new-model
aaa authentication login eap group dot1x
aaa authentication login EAP-List group dot1x
aaa authorization exec defaut local
dot11 syslog
dot11 ssid NBCorporate
vlan 1
authentication open eap EAP-List
authentication key-management wpa optional
dot11 ssid NBGuest
vlan 20
authentication open
guest-mode
wpa-psk ascii 0 Gu35t551d
no username cisco
username admin privilege 15 secret 0 NBR3M0tE
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip wep128
encryption vlan 20 mode ciphers tkip
broadcast-key vlan 1 change 30
broadcast-key vlan 20 change 30
ssid NBCorporate
ssid NBGuest
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 20
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet
ip address 192.168.55.2 255.255.255.0
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface GigabitEthernet0
bridge 1 route ip
line con 0
privilege level 15
line vty 0 4
cns dhcp
end
Any help is GREATLY Appreciated. Thanks!
