cisco 891-w nat issue
moelsaid
Hello, I have a Cisco router 891-w and I'm trying to use it at home, but it does not login to the internet, this is my configuration.
any help, please ?
Router#sh running-config
Building configuration...
Current configuration : 2611 bytes
version 15.4
hostname Router
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 192.168.20.1
ip dhcp pool voice
 network 192.168.20.0 255.255.255.0
 option 150 ip 192.168.20.1
 default-router 192.168.20.1
ip cef
no ipv6 cef
license udi pid CISCO891W-AGN-A-K9 sn FTX1529816S
redundancy
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 ip address 192.168.1.65 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0
 ip address dhcp
 duplex auto
 speed auto
interface wlan-ap0
 no ip address
 arp timeout 0
interface Wlan-GigabitEthernet0
 no ip address
interface Vlan1
 ip address pool voice
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet8 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet8
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
 max-ephones 4
 max-dn 4
 ip source-address 192.168.20.1 port 2000
 cnf-file perphone
 max-conferences 0 gain -6
transfer-system full-consult
 create cnf-files version-stamp 7960 Jun 01 2019 07:12:16
ephone-dn  1
 number 1010
ephone-dn  2
 number 2020
ephone  1
 device-security-mode none
 mac-address 40F4.ECEE.78D0
 type 7975
 button  1:1
ephone  2
 mac-address 000F.3493.FA40
type 7960
 button  1:2
line con 0
line 1
 modem InOut
 speed 115200
 flowcontrol hardware
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 login
 transport input none
end
8 Replies 8
luis_cordova
Hi @moelsaid ,
I think it is necessary to configure the 192.168.20.0 network in an interface, besides, that interface must be left as ip nat inside.
hello @luis_cordova
thank you for your response but can you explain more, I'm kinda confused
thank you
Collaborator
Re: cisco 891-w nat issue
Hi @moelsaid ,
Everyone's tags (0)
  • Data Classification:
  • Cisco Public
Accept as Solution
Hi  @moelsaid ,
You have the output interface configured (FastEthernet8).
You have the nat configured to translate the 192.168.20.0 network, but, you do not have that network configured in any interface.
In addition, you must indicate that this interface will be the input interface after the translation.
Maybe:
FastEthernet7
ip address 192.168.20.1 255.255.255.0
ip nat inside
hello @luis_cordova
I already did that on interface VLAN 1  and make to nat inside, Does the nat inside should be in phycial interface, not VLAN interface ??
Router(config)#do sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Async1                     unassigned      YES unset  down                  down
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
FastEthernet5              unassigned      YES unset  down                  down
FastEthernet6              unassigned      YES unset  down                  down
FastEthernet7              unassigned      YES unset  up                    up
FastEthernet8              192.168.1.65    YES NVRAM  up                    up
GigabitEthernet0           unassigned      YES NVRAM  down                  down
NVI0                       192.168.1.65    YES unset  up                    up
Vlan1                      192.168.20.1    YES NVRAM  up                    up
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
wlan-ap0                   unassigned      YES NVRAM  up                    up
Router(config)#
No it can be either logical or physical depending on setup , you need an inside NAT and outside on the public interface , the modem connected must also be in bridge mode so it pulls the external IP address back onto the Cisco router and basically just becomes dumb terminal
example in this link ,with wireless config setup too
https://community.cisco.com/t5/wireless-mobility-documents/configuration-example-of-861w-881w-891w-series-isr-s/ta-p/3112716
interface vlan 1
no shutdown
Hi @Hulk8647 ,
If the network 192.168.20.0 is in the interface vlan1, it is expected that the devices will be associated with that vlan.
Within the interface vlan1, you must indicate that this will be the input interface for the NAT:
interface vlan 1
ip nat inside
no shutdown
Hello
conf t
Interface vlan 1
ip route-cache
no ip route 0.0.0.0 0.0.0.0 FastEthernet8
ip route 0.0.0.0 0.0.0.0 FastEthernet8 192.168.1.X  (next hop ip address)
Access-ports
int x/x
switchport mode access
spanning-tree portfast
Kind Regards
Paul
