C9500 stackwise-virtual mix port
shiran.wang
i want to confirm if c9500 stackwise-virtual interface support mix 40G with 10G or 25G,
Can someone share it?
Reza Sharifi
You can use 10Gig or 40Gig
Cisco StackWise Virtual is a network system virtualization technology that pairs two switches into one virtual switch. Switches in a Cisco StackWise Virtual solution increase operational efficiency by using single control and management plane, scale system bandwidth with distributed forwarding plane, and assist in building resilient networks using the recommended network design. Cisco StackWise Virtual allows two physical switches to operate as a single logical virtual switch using a 40G or 10G Ethernet connection.
link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/ha/b_169_ha_9500_cg/configuring_cisco_stackwise_virtual.html
10G or 40G Ethernet connections. SVL is established using the 10G or 40G interfaces on the supported switch models. However, a combination of both the interfaces is not supported.
Spooster IT Services Team
