I am trying to replace an old Cisco ASA5505 with a Cisco892fsp.
On the LAN - besides hosts etc. - is an Apple Wireless setup (Airport Extreme as main and some Airport Express as extenders)
The Wireless setup is announcing 2 SSID´s - One for local LAN access and a guest Network. - The Airport Extreme is setup as a bridged device (no routning enabled).
On the ASA5505, the Airport extreme was connected on a TRUNK port. - Untagged frames (local LAN) access would be Applied to vlan1 and as the Airport Extreme tags the guestnetwork with VLAN1003.... interface vlan1003 is used as the Guestnetwork.
No problem with the ASA - (although I am well aware, that Apple is using a reserved vlan)....
But on the cisco892fsp i´am now stuck... in IOS i can´t change or use vlan1003 as a nomal vlan, and i can´t use vlan mapping, as it is apparently not supported on the 89x switchmodule... don´t even know if it would work, but i was the only solution that came to mind.
Any ideas to get this working ?? - I can´t be the only one stuck with the vlan1003 issue :)
Regards /Ole
