Cisco 9200 AD CA SSL certificate CSR and import
I have read the Cisco documentation on HTTPS certs for Cisco IOS here
Sadly, I don't quite understand what a "TrustPoint" is, and what steps I do and do not need to take to generate a CSR to submit to our internal AD CA. It's also talking about URLs, and I'm not sure which CA URLs it is asking for.
My 9200 stack has a default trust point and self signed cert configured automatically.
Can anyone tell me which steps I need to follow in order to create a "TrustPoint" for our CA, and how to then generate a CSR?
Many thanks.
James
I have a resolution to this problem. Cisco support advised my issue was that the cert was missing DEK header information.
So, my process is;
1. Generate key and CSR using below command:
openssl req -newkey rsa:2048 -subj "[certificate_details]" -sha256 -keyout [key_name].key -out [csr_name].csr -config [ConfigFilePath]\openssl-san.cnf
2. Convert the key or add DEK header info using the below command:
openssl rsa -in keyin.key -out keyout.key -des3
3. Generate cert from CSR
4. Import cert to switch using below command:
crypto pki import TRUSTPOINT_NAME pem terminal password KEY_PASSWORD
5. Enter the root CA cert, key and cert text when prompted
6. Set the trustpoint as the one used for https using below command:
ip http secure-trustpoint TRUSTPOINT_NAME
Hope this helps others.
James
20 Replies 20
balaji.bandi
Just make it clear, what are you trying to achieve here ? Do you like the device web GUI cert to be authorized by Local CA?
BB
Yes, exactly.
I would like to apply an internally issued SSL certificate to the Web GUI, so that when browsing to the Web GUI the certificate is trusted (rather than showing a certificate error because it is using a self-signed cert).
Many thanks
James
Trustpoint to your CA.
here is some good steps ( for Router) - but same should work for Switch too.
https://www.entrust.com/knowledgebase/ssl/how-to-install-ssltls-certificates-on-cisco-appliance-using-cli
BB
Sorry, still a little lost.
Do I need to;
1. Generate a keypair:
crypto key generate rsa general-keys label MYCAKEYS exportable modulus 2048
2. Create a trustpoint for my CA:
crypto ca trustpoint MYCA
enrollment terminal
chain-validation stop
3. Create a trustpoint for the cert I am going to generate from my CA:
crypto ca trustpoint MYSWITCHDNSNAME
enrollment terminal
chain-validation continue MYCA
$O=MYORG, OU=MYOU, CN=MYSWITCHDNSNAME
fqdn MYSWITCHDNSNAME
rsakeypair MYCAKEYS
4. Generate the CSR:
crypto ca enroll MYSWITCHDNSNAME
5. Submit the CSR to my CA and generate a certificate
6. Import the cert:
crypto ca authenticate MYSWITCHDNSNAME
PASTE BASE64 CERT
If that's correct, I will give this a go.
James
Hi James,
Your steps match with what Entrust has on their site. See the below link:
Just remember if you want to use a public CA, you have to renew it once a year or every 3 years (depending on your contract with the provider). Not sure how large your teams are, but getting the certs from CA  is usually done by the server team.
I get stuck at step 2.
"Crypto ca" is not a recognised command:
post below information :
show version
show ip ssh
crypto ca ?  (what option you see ?)
BB
Show version returns a lot. Is there a specific bit you want to see, or shall I paste the whole lot?
Key one I suspect might be this:
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    C9200L-24T-4G      17.03.03          CAT9K_LITE_IOSXE      INSTALL
     2 28    C9200L-24T-4G      17.03.03          CAT9K_LITE_IOSXE      INSTALL
show ip ssh:
SSH Enabled - version 1.99
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,x509v3-ecdsa-sha2-nistp256,x509v3-ecdsa-sha2-nistp384,x509v3-ecdsa-sha2-nistp521,rsa-sha2-256,rsa-sha2-512
Hostkey Algorithms:x509v3-ssh-rsa,rsa-sha2-512,rsa-sha2-256,ssh-rsa
Encryption Algorithms:aes128-gcm,aes256-gcm,aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512
KEX Algorithms:ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-126708313
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDGijhpzD7cPY5s1vKVPD0vp+Zgg4326Kn7MiLsBHSu
kOtKRwxaYbzCjE1MwsWEGwPhBKPY7AGdeLPdmwcP0xX08CbqMSBlfIyIciw5gP+Yd+y28CkD8Zi3yZme
/APYwuaNj43XlHqebHkRsnIsTTEWgutBmupR+pckx6h61k8DxjsERl85cFMhoyoLRaviSEf/PAJ3wBSq
0aMQvbDEmwrrq4qdNVoI8kYYhW9OiHgjw4wEHMmGVtjiloAx/pMc7FMnKgR2xRrjdWCY4JO3tEdigS4t
cqB+lF4lcH0kp0GHkSSMN3bjUrPhZWPNczWrC0Zvd21y+8l9ihY5KNJimZhj
crypto ca ?:
ASP-COSW-01#crypto ca
% Invalid input detected at '^' marker.
Let me know if you need anything else.
Cheers
James
command need to be excute in config more
config t
(config)#crypt ?
and
(config)#crypt  ca ?
BB
Yes, unfortunately it is still unrecognised:
Many thanks
James
apologies..i have observed that you have LITE image, that may not work..
BB
Thanks.
Any suggestions on how to find steps to complete for the image we have?
Is there perhaps a way instead to do it through the Web GUI rather than CLI?
Many thanks
James
LITE do not support i guess, you need change the IOS image.
BB
Surely there must be some way to just create a CSR to submit to my internal CA, either by CLI or in the GUI?
What is involved in changing the image, and can it be done without affecting my current running config?
Cheers
James
