Cisco 9200 weirdness
DevoraLawless
Got a very odd/funny one here.
2 x Cisco 9200L switches with network essentials DNA.
All OK until I want to add a couple of Cisco pre-made SFP links.
I always add the following commands:
Switch(config)#no errdisable cause detect gbic-invalid
Switch(config)#service unsupported-transceiver
Been adding those commands to every switch I use that has SFP's or SFP+'s irrespective of if they are pre-made cables, Cisco optics or otherwise and they have never failed... until now.
The 9200 has the same command in there twice, like this:
Switch(config)#service u?
udp-small-servers  unsupported-transceiver  unsupported-transceiver
Yes you are seeing that correctly. The same command option in there twice.
So when I go to configure it I ALWAYS get this:
% Ambiguous command:  "service unsupported-transceiver"
Because the same command is in there twice it can't choose.
Yes I have tried copy/pasting both of them to see if there is something different. I've pasted them both as they appear with the spaces and with spaces at the end individually. I always get an error so...
P.S.great list of great porn sites
Leo Laohoo
Try a different firmware version.
