Cisco 9200L-24P or 48P POE+ with single power
Babar82
Hi all, i have a question with 2 Cisco 9200L POE+ devices:
If i use a Cisco 9200L-24P-4G with single power PWR-C5-600WAC without additional power, the available POE power is 370W.
If i want to use POE+ devices, i can use up to 12 POE+ devices, and if a want to use both POE and POE+ devices, i can use it both without exceed the threshold of 370W, is correct?
If i use a Cisco 9200L-48P-4G or 4X with single power PWR-C5-1KWAC without additional power, the available POE power is 740W.
If i want to use POE+ devices, i can use up to 24 POE+ devices, and if a want to use both POE and POE+ devices, i can use it both without exceed the threshold of 740W, is correct?
I ask this to confirm, because for example Cisco 2960S datasheet explain crearly that, for example, if you have 370W POE power, you can use up to 12 POE+ devices, or 24 POE devices.
Thank you.
Leo Laohoo
How many PD and how much power draw do each PD require -- This is the question you should be asking.
Now, i don't know the exact number and the power of every PD.
My goal is to know and understand if i can use both POE and POE+ devices without exceed the total power budget.
Example 5 POE+ devices and 10 POE devices (total 304W).
