Cisco 9300 losing config after reloading
Pavan.0703
I am using Cisco 9300 48UXM-E, after configuring when I reload the switch I am losing configuration. Switch is coming as new and when we use command copy start run config is coming back. On my research I understood that config-register is not changing from 0x2142 to 0x2102 after reloading. Can anyone please help me to overcome this issue.
2 Accepted Solutions
@Pavan.0703 wrote:
I tried copy run start.
But there is no change in config register
Did you check the configuration for the offending line I've pointed out?
Following worked for me on a 9300-48U switch
switch (config)# no system ignore startupconfig switch all
Copy run start
Reload
Didn't need to include the config-register command
21 Replies 21
luis_cordova
Hi @Pavan.0703,
Two tests:
-Try with the command: S#copy running-config startup-config
-Check the current register of your device
Would the original poster please post the output of show version. We would like to verify the value of the config register.
Rick
Rick
Several of us seem to be operating from the assumption that the issue is the value of the config register. There have been several requests to verify what is the value of the config register but so far no information about the content of the config register. Leo has identified another very interesting possibility about the issue. But so far no response to his suggestion either.
The most recent post from the original poster seems to suggest that he believes that doing copy run start should change the value of the config register. I do not have experience with the 9300 switches. But on every Cisco switch with which I do have experience doing copy run start has no effect of changing the config register. You change the value of the config register with a configuration command in global config mode or you change the value in rommon.
Rick
Rick
Leo Laohoo
Check the config if this command is present:  system ignore startupconfig switch all
Crystal.Young
Entering the following commands worked for me:
switch (config)# switch all config-register 0x102
Copy run start
Reload
does not work on a 9300 running 17.3.5 for me
Post the complete output to the following commands:
  1. sh boot
  2. sh romvar
Hi Leo,  I am using 17.6.4 version on my 9300 switch and it also has same symptoms
Switch#show romvar
ROMMON variables for Active Switch
ABNORMAL_RESET_COUNT=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOARDID=24664
BOOT=flash:packages.conf;
BSI=0
CONSOLE_MIRRORING_DISABLE=0
DC_COPY=yes
D_STACK_DAD=
D_STACK_DISTR_STACK_LINK1=
D_STACK_DISTR_STACK_LINK2=
D_STACK_DOMAIN_NUM=
D_STACK_MODE=
IMAGE_UPGRADE=no
LICENSE_BOOT_LEVEL=network-advantage+dna-advantage,all:ngwc;
MAC_ADDR=C0:64:E4:71:98:80
MANUAL_BOOT=no
MCP_STARTUP_TRACEFLAGS=00000000:00000000
MODEL_NUM=C9300-24T
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-18270-03
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FJZ23221FL9
RANDOM_NUM=501941253
RECOVERY_RELOAD_DISABLE=
RET_2_RCALTS=
RET_2_RTS=
ROMMON_AUTOBOOT_ATTEMPT=3
SWITCH_IGNORE_STARTUP_CFG=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=15
SYSTEM_SERIAL_NUM=FJB2323B043
TEMPLATE=access
USB_DISABLE=0
VERSION_ID=V02
Switch#sh boot
Switch 1
Current Boot Variables:
BOOT variable does not exist
Boot Variables on next reload:
BOOT variable = flash:packages.conf;
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
Switch#
Post the following output:
  1. dir
  2. sh run all | i service
  3. sh version
  4. sh log
I want to determine if this is due to C.SCve62353 or not
Copy run start
Reload
Rob Miller
Level 4
Level 4
Am I nuts?  Lots of people asking about config-register.  I don't see anyway to find or set that on a 9300 switch.  Sh Ver doesn't show it, the switch all config-register command listed in here isn't recognized in config mode or just enabled mode.  I feel like there's router trouble shooting going on here and it's a switch at least in my case it's a switch and doesn't take router specific commands.
    @Rob Miller      - FYI : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
