Cisco 9300 port channel
rsblind
I recently was setting up a port channel on a Cisco 9300 and with my first config the ports were suspended. Here's what I had.
Port Channel config
interface Port-channel1
 description DC-ExpInet
 switchport access vlan 2
 switchport mode access
Ports config
interface TenGigabitEthernet1/1/2
 description Exp Inet 1
 channel-group 1 mode active
interface TenGigabitEthernet3/1/2
 description Exp Inet 2
As mentioned this didn't work. I had to define everything from the port channel on each port and then they connected. I thought I just had to define the commands in the po1 and the ports would inherit the po1 settings.
Here's my final config that is working...
Port Channel
Ports.
Thanks in advance
RS
Need to config port member identical to PO' otherwise it will not work.
Note:- only channel-group <> mode <> is use only in port member
MHM
5 Replies 5
MHM
So because I had a "description" it made it fail?
No, the steps should be the following
conf t
interface range Ten 1/1/2, Ten 3/1/3
 spanning-tree portfast enable
And that's it.
Not because description but because you dont specify port mode and vlan allow in port.
MHM
rsblind
Thanks all...
