CISCO 9300 STACK PROBLEM
Virendra Prajapati
Community Member
Hi All,
Please suggest me , i am getting issue with the making of cisco 9300 in stacking, below is the snap shot of the switch version.
VirendraPrajapati_0-1688108135031.pngVirendraPrajapati_1-1688108150378.pngVirendraPrajapati_2-1688108231694.pngVirendraPrajapati_3-1688108333433.png
13 Replies 13
Leo Laohoo
Are the stacking cable even connected?
YES...
Each end of the stacking cable has a "Cisco" logo.  Are they facing UP?
Thank you for your quick support, but now i am getting below error
Stacking cable shows the "Cisco" logo is pointing DOWNWARDS.
Fix that up first and we'll deal with the next problem.
Now i  fixed the stacking cable that you are mention above, but still getting same issue
Seriously, WTF are you doing???  Is this some kind of deranged joke?
The screws to the stacking cables are LOOSE!
Do you honestly think the stacking cable screws are some kind of "decorations"?
Look at the so-called "console cable" at the back!  It is flippin' FRAYED!
Dear Leo
Thank you for the giving me such kind of information.
When i add another one more  switch with the stack, its working fine, but not with previous switch.
software auto-upgrade enable
Enter above command into the switch master.
show version  in both SW1 and SW2 check, I think it not match
