Cisco 9300X 12y
I know this has been asked many times in this group. But I've been scratching my head and pulling my hair. We have cisco 4500x core switch and we've been trying to upgrade that core switch to cisco 9300x 12y core switch. We copied the configuration and everything and we are sticking to the same config and the same ip scheming and all of that. And for some reason.  When we plugged back the sfp modules which is basically 10g we are not getting internet connection.We can ping all the routes, next hop and even the dns server from the switch.But to the idf closets we are not getting ip address.And also I have few questions regarding these switch:
1. On the show ip interface brief command, it shows we have more than 12 ports but physically we have only 12 physical ports.
2.Does our current sfp module which is 10g compatible with the switch we are trying to upgrade which is cisco 9300x 12y.
I'm sorry for my english or grammar.But do enlighten us.
Thanks!
2 Accepted Solutions
See below. If you are using a 10gig interface to connect to Gigaman, shouldn't the IP address be configured under interface te1/1/1?
If yes, is interface 1/1/1 in up-and-up mode?
Can you post the output of "sh ip int brief"
Also, can you ping the DHCP server from the new switch?
interface TwentyFiveGigE1/0/1
no switchport
ip address 192.168.25.2 255.255.255.252
ip pim sparse-dense-mode
duplex auto
interface TenGigabitEthernet1/1/1
description To Tech - Gigaman
no switchport
no ip address
what @Reza Sharifi tries to point out is
that on this platform all  Ten1/1/1 and Twentyfive1/1/1 Hundred1/1/1 are references to the same physical interface (not hidden interface)
instead of changing the speed of the interface configuration to Tengig ,you disable Twentyfive1/1/1 and Hundred1/1/1 and enable Ten1/1/1,
and you use Ten1/1/1 for all further configuration
11 Replies 11
pieterh
show ip interface brief command, is used for "routed" ports, this includes Loopbacks, VLANS, tunnel interfaces etc., not limited to physical ports!
-> use "show interface status" to show the physical switchports
in combination use "show inventory" to see if the SFP's are properly detected
Reza Sharifi
In addition to the info Pieterh provided since the physical interfaces could be 1/10/25 or 40, the "sh ip int brief" will list all of them using the same numbering interface. See example:
GigabitEthernet1/1/2
GigabitEthernet1/1/3
GigabitEthernet1/1/4
Te1/1/1
Te1/1/2
Te1/1/3
Te1/1/4
Also, 10G SFPs from a 4500x should be compatible with 9300.
Are you able to ping the DHCP server (192.168.1.63) from the new switch?
Can you post the output of "sh run" from the new switch?
Hello Reza,
This is the running config from the new switch:
Current configuration : 8313 bytes
! Last configuration change at 23:54:29 UTC Mon Feb 19 2024
version 17.9
! Call-home is enabled by Smart-Licensing.
service call-home
platform punt-keepalive disable-kernel-core
hostname HS9300X-12Y-Core
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch 1 provision c9300x-12y
login on-success log
vtp version 1
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
quit
license boot level network-advantage addon dna-advantage
memory free low-watermark processor 131050
diagnostic bootup level minimal
spanning-tree mode pvst
spanning-tree portfast bpduguard default
redundancy
mode sso
crypto engine compliance shield disable
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
no switchport
duplex auto
interface TwentyFiveGigE1/0/2
switchport mode trunk
interface TwentyFiveGigE1/0/3
interface TwentyFiveGigE1/0/4
interface TwentyFiveGigE1/0/5
interface TwentyFiveGigE1/0/6
interface TwentyFiveGigE1/0/7
interface TwentyFiveGigE1/0/8
interface TwentyFiveGigE1/0/9
interface TwentyFiveGigE1/0/10
interface TwentyFiveGigE1/0/11
interface TwentyFiveGigE1/0/12
no switchport
no ip address
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface TwentyFiveGigE1/1/3
interface TwentyFiveGigE1/1/4
interface TwentyFiveGigE1/1/5
interface TwentyFiveGigE1/1/6
interface TwentyFiveGigE1/1/7
interface TwentyFiveGigE1/1/8
interface HundredGigE1/1/1
interface HundredGigE1/1/2
interface AppGigabitEthernet1/0/1
interface AppGigabitEthernet1/0/2
interface Vlan1
description Management
ip address 172.24.1.1 255.255.255.0
interface Vlan2
description Data and IMS
ip address 172.24.96.1 255.255.240.0
ip helper-address 192.168.1.63
interface Vlan52
description Camera
ip address 172.24.52.1 255.255.255.0
interface Vlan100
description Voice
ip address 172.24.112.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.25.1
ip route 172.19.0.0 255.255.0.0 192.168.25.6
control-plane
service-policy input system-cpp-policy
line con 0
password fatman
login
stopbits 1
line vty 0 4
password fatman
logging synchronous
login
transport input all
transport output all
line vty 5 31
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
no switchport
duplex auto
no switchport
no ip address
Hello Reza,
That's where trying to figure it out. Physically, the cisco 9300x 12y has 12 ports where it has all the   interface is TwentyFiveGigE. We need guidance on how to connect the Gigaman port to the TenGig port of the cisco 9300x 12y. I am literally pulling my hair on how to connect the Gigaman to the TenGig port.I even flipped the switch if theres a hidden port in the switch.Your guidance is really appreciated. Thanks!
Hello Pieterh,
Thank you for the enlightenment. So in my understanding, the Tengig port and TwentyfiveGig port sits on the same physical port.Its just a matter of configuring that port to communicate to the next hop.We will try this again.And again , thank you for your help.
I'm sorry for being so noob.But quick question.How do you disable TwentyFive 1/1/1, Hundred 1/1/1.And enable the Ten1/1/1.Because everytime I plug in the sfp module the default that will come up is the Twentyfive1/1/1.I already configure the Ten1/1/1 as per y'all recommendation.But still no luck.
look at commands as described in this document :
Interface and Hardware Components Configuration Guide, Cisco IOS XE Dublin 17.12.x (Catalyst 9300 Switches) - Configuring Interface Characteristics [Support] - Cisco
Step 6
interface interface-id
Example:
Device(config)# interface HundredGigabitEthernet1/0/25
Specifies the interface to be configured, and enters interface configuration mode.
Step 7
enable
Example:
Device(config-if)# enable
Enables breakout on an interface.
pieterh
Wait a minute..... I noticed something strange.
>>> default that will come up is the Twentyfive1/1/1 <<<
is this really 1/1/1 or should this read 1/0/1 ?
also take a look at this post Solved: Cisco 9300x-12y-a Interface Naming - Cisco Community
where @Leo Laohoo says:
Depends on the firmware version.  Older version will depend on what optics is plugged in, for example, if a GLC-SX-MMD is connected to port 1 then the interface will be called Gi1/0/1.  Any configuration entered into Ten 1/0/1 or Twe 1/0/1 will not be accepted.
In later 17.x.x, if the same GLC-SX-MMD is connected to port 1, it is fine for the configuration to be entered in Twe 1/0/1.
