Cisco 9407R stucks at --- System Configuration Dialog --- Would you like to enter the initial configuration dialog? [yes/no]
mateens
switch is not connected to anything other than console. Restarted many times but it stucks at same spot.
balaji.bandi
What client you using for the Console ( Putty or Secure CRT)
Check the Console connection make sure flowcontrol none ( putty by default set to different).
BB
balaji.bandi
BB
