Showing results forĀ
Search instead forĀ
Did you mean:Ā
CISCO 9410 STACKWISE VIRTUAL FEATURE
Kevin100
Level 4
Level 4
Hai we need stack wise virtual feature for a big project with Cisco 9410 and sup1
at present I couldn't see any IOS  version support that feature, but newer ones with 9404 and 9407 are supported ,any one knew this feature will come soon
7 Replies 7
Leo Laohoo
Wait for 16.10.1. Hopefully before the end of 2018.
Hai
Any body confirm stackwise virtual feature for 9410  with 16.10.1 code.
In release notes its not clear,which feature will help to work as one switch,like VSS
Its available even before 16.10 , its in 16.8 and 16.9 too as below configuration guide
staxckwise is basically same as VSS same concept
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/configuration_guide/ha/b_169_ha_9400_cg/configuring_cisco_stackwise_virtual.html
Hai Mark
Its showing not for 9410 , for other models available
See on feature guide,no 9410
see from that guide
Cisco StackWise Virtual is supported only on Cisco Catalyst 9404R and Cisco Catalyst 9407R switches.
Why such a required feature not in 9410
can u check
sorry your right my bad , and i dont see any other release stating its coming for that specific model , wonder why they didnt add it to the 9410
Dear Mark
Please raise this to Cisco if you can
i am screwed as we have big project require this feature
thanks you
