Cisco 9500 stackwise-virtual : problem with stackwise virtual link
marzi
Level 4
Level 4
Hi all
I need to form a stackwise virtual, using two cisco 9500-48Y4C with IOSXE Version 17.15.03.
For now, I've only two QSFP 40G LR4 SFP, so I can create only one switch virtual link.
Anyway I would to prepare another couple of port for further switch virtual link.
My configuration is :
Switch(config)#interface range hu1/0/51-52
Switch(config-if-range)#stack
Switch(config-if-range)#stackwise-virtual link 1
I receive the follow error message :
WARNING: Interface HundredGigE1/0/52 could not be added to stackwise-virtual link 1
The speed of the interface HundredGigE1/0/52 does not match the speed of the existing interface(s) on stackwise-virtual link 1
Check the output of 'show stackwise-virtual link' to see the mismatched speeds
% Interface range command failed at HundredGigE1/0/52
Exiting from range submode without applying rest of the commands in range to avoid unwanted issues
I'm sure that there are not difference between the Hu1/0/52 of the switch1 and switch2 (Hu1/0/51 is not connected for now)
Switch2#show interfaces Hu1/0/52 status
Port Name Status Vlan Duplex Speed Type
Hu1/0/52 connected 1 full 40G QSFP 40G LR4 SFP
Switch1#show interfaces Hu1/0/52 status
The speed can't be forced to 40000G.
Is there anyone that have experience of this problem ?
Could be a bug ?
Thanks in advance
fabrizio
2 Accepted Solutions
balaji.bandi
What SFP on this port - can you post show interface hun1/0/51 and same 1/0/52
How about trying normally instead of the range command?
interface hu1/0/52
If you are short on SFPs, make 1 port with a command, remove the SFP, add it to another port, and complete the configuration. That should work.
BB
I fixed my problem recovering other two QSFP 40 G compliting the configuration as manual says
Other solution doesn't works
Thanks for all
Have a nice day
Fabrizio
balaji.bandi
interface hu1/0/52
BB
Hi balaji
Thank for your replay,
I'll do it and will update the community.
I've only one question :
Yes, I can try configuring only one port, but in the future will be possible to double the virtual link without a reload of the stackwise virtual ?
Yes, you can add if that is your requirement without reloading the SVL domain switches.
BB
Thanks for all
Have a nice day
Fabrizio
