cisco 9500 switch major error
Manish Manwal
we are receiving below error in 9500 stack. i checked power supply is ok and temperature is also green. the module is different every time. TenGigabitEthernet2/0/1 TenGigabitEthernet2/0/40 , TenGigabitEthernet2/0/30 etc.
MAJOR Event: Cisco: Temperature problem. Currently, Temperature (TenGigabitEthernet2/0/1 Module Temperature Sensor) status: unavailable
MAJOR Event: Cisco: Power Supply problem. Currently, Power Supply (TenGigabitEthernet2/0/1 Supply Voltage Sensor) status: unavailable
SW#sh env power
SW PID Serial# Status Sys Pwr PoE Pwr Watts
2A PWR-C4-950WAC-R DCI2514M74E OK Good n/a 950
2B PWR-C4-950WAC-R DCI2514M74G OK Good n/a 950
SW#sh environment temperature
Switch 1: SYSTEM TEMPERATURE is OK
Inlet Temperature Value: 24 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 56 Degree Celsius
Outlet Temperature Value: 35 Degree Celsius
Yellow Threshold : 105 Degree Celsius
Red Threshold : 125 Degree Celsius
Hotspot Temperature Value: 51 Degree Celsius
Switch 2: SYSTEM TEMPERATURE is OK
Inlet Temperature Value: 23 Degree Celsius
Outlet Temperature Value: 34 Degree Celsius
Hotspot Temperature Value: 52 Degree Celsius
THANKS
MANISH MANWAL
9 Replies 9
Mukesh
Hi Manish,
Can you try reseat and see if the issue is fixed, if not I suggest raise a case with cisco TAC they will analyse it further. If they cant find cause they likely to do RMA
Kind regards
Mukesh
balaji.bandi
this is related to port that was referring, Do you have any SFP Module installed on that port ? TenGigabitEthernet2/0/1
what version of IOS XE Code ?
BB
yes sfp module is installed.
XE : 17.06.04 CAT9K_IOSXE
THANKS
MANISH MANWAL
post below output :
#show interfaces ten 2/0/1 transceiver detail
BB
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te2/0/1 17.7 85.0 75.0 -5.0 -10.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te2/0/1 3.17 3.60 3.50 3.10 3.00
Current Threshold Threshold Threshold Threshold
Port Lane (milliamperes) (mA) (mA) (mA) (mA)
Te2/0/1 N/A 6.3 15.0 14.0 2.0 1.0
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port Lane (dBm) (dBm) (dBm) (dBm) (dBm)
Te2/0/1 N/A -3.0 1.0 0.0 -6.0 -7.0
Receive Power Threshold Threshold Threshold Threshold
Te2/0/1 N/A -3.4 2.0 1.0 -12.0 -13.0
THANKS
MANISH MANWAL
Looks ok for me - if you get chance in the maintenance window, reseat the SFP
Do you see any performance issue other than logs ?
BB
no, no other performance issue. all good.
this is happening for multiple sfp module.
THANKS
MANISH MANWAL
hmm could be bug - we are running 17.6.4 not see that issue. its stable version
until you like to go to 17.9.3
BB
Leo Laohoo
Contact Cisco TAC and arrange for an RMA.  The motherboard is failing.  The circuitry for switch 2, port 1 is experiencing issues.
