Cisco 9600 and QinQ a vlan interface
trondaker
Level 3
Level 3
Struggeling a bit with Azure Expressroute direct and QinQ - we have a cat9k facing Azure, and we need qinq for more circuits over a single connection - however, i cant quite see how i can get a SVI to be wrapped in a s-tag? So say we have vlan 2 towards Azure as the s-tag. Port facing Azure configured as a trunk with vlan 2 on it - but where do i do the dot1q-tunnel-part? Is it possible to do this on a single box, or do i have to be one hop back from the switch doing the tunneling?
trondaker
Level 3
Level 3
Apparently using the following:
interface x/x/x.100
 encap dot1q 100 second-dot1q 1000
Should theoretically work, but on our 9k it didnt. Ended up doing a back to back port-channel with:
int vlan yyy
 desc peering to azure
int po1
 desc towards dot1q-tunnel source
switchport mode trunk
switchport trunk allowed vlan yyy
int po2
 desc source for dot1q-tunnel to azure
 switchport access vlan 7 <- s-tag azure expects, this tags whatever comes in from the other side with 7 as s-tag
 switchport mode dot1q-tunnel
Guess its an old-school way of doing things, but the second-dot1q way didnt work so..
