Cisco 9606R - PVST to connect 6506 having PVST
adeebtaqui
Level 4
Level 4
Greetings,
Can we configure the old PVST on new cisco 9600/9500 to connect spanning tree with an existing 6506 having PVST?
Kindly advise the best way to conect before we remove 6506 out
balaji.bandi
Personally i do not see any issue IOS XE do support your requirement : ( but if you moving to new world i take advantage of new featured rapid pvst)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-12/configuration_guide/lyr2/b_1612_lyr2_9500_cg/configuring_spanning___tree_protocol.html
BB
Problem is the live existing 6506 is having PVST configured , so we need to follow it on new 9600 being connected to 6506
9500 config guide is showing PVST+. Can PVST be configured?
difference between pvst  and pvst+
802.1q (standard) supports only one single instance of STP
  •     native VLAN (Common Spanning Tree)
  •     one STP instance -
PVST (Cisco proprietary)
  •     Support one STP instance per each VLAN
  •     uses ISL trunk only.
  •     Doesn't support 802.1q
PVST+ (Cisco proprietary) Enhance PVST capabilities by allowing to transport PVST over 802.q :
  •     native VLAN over "Common Spanning Tree"
  •     Each per-VLAN STP is encapsulated using a special Multicast MAC and transported
BB
