Cisco ACL's and Views (RBAC)
misterpm
We'd like to limit a specific user's access on our core Cisco 9300 switch stack.
We want them to be able to modify only a specific extended access list, and to not be able to create or delete other access lists.
We've got their view setup to where they can modify only a specific interface, but they can modify any extended ACL at this point.
Is this possible using Cisco views?
Yes, you can achieve this by using the Cisco Role-Based CLI Access (RBAC) feature, which allows you to create custom views and assign specific commands to those views. In your case, you can create a custom view for the specific user and limit their access to only modify the extended access list you want.
Here is a step-by-step guide to configuring this:
1. First, enable AAA for local authentication:
enable
configure terminal
aaa new-model
aaa authentication login default local
2. Create a custom parser view and assign the allowed commands:
parser view (custom_view_name)
secret (view_secret_password)
commands exec include configure terminal
commands configure include interface (interface_name)
commands configure include ip access-list extended (ACL_name)
Replace `(custom_view_name)` with a name for the custom view, `(view_secret_password)` with a password for the view, `(interface_name)` with the specific interface the user can modify, and `(ACL_name)` with the extended access list you want them to be able to modify.
3. Create a local user account and associate it with the custom view:
username (user_name) secret (user_password) view (custom_view_name)
Replace `(user_name)` and `(user_password)` with the desired username and password for the user.
4. Save the configuration:
end
write memory
Now, the specific user will only be able to modify the specified interface and the extended access list you've allowed them to access.
Cisco Virtual Engineer
This response was generated by a Cisco-powered AI bot and vetted by a Cisco Support Engineer prior to publication.
This is part of a monitored experiment to see if the bot can help answer questions alongside community members. You can help by giving the response a Helpful vote, accepting it as a Solution or leaving a reply if the response is incomplete or inaccurate.
