Cisco AP1142N Radius Issue
vobpcdcisco
Greetings,
I currenly have a cisco AP1142N configured to work with our radius server (It was already configured when I took over the network). I order two additional access points for building coverage on multiple floors. Currently, I uploaded the config of the orginal access point to the new device and I can access the device via web and the ssid is being broadcasted. I then added in the access point into IAS with the radius secret key to our Radius server. When I go to connec to the new access point w/ domain credentials I am not able to establish a connection. I am not very familiar with CISCO products. I followed a video to get the access point up and running w/ an IP from CLI so I could access the web interface and upload the edited config.txt file. Are there any issues with setting up multiple access points w/ a single windows radius (IAS) server?
John
7 Replies 7
John Blakley
You can use a single radius server with no issues. Can you post the config? Are your others working with eap authentication?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Yes, we are using EAP Open Auth. Below is the conf of my access point. Also, the orginal wifi ap is working properly.
version 12.4
no service pad
service password-encryption
hostname vhall-1
logging rate-limit console 9
enable secret 5 $1$8rxD$XTK4A5n7UjtiJWRKaUCu8.
aaa new-model
aaa group server radius rad_eap
server 10.0.0.2 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip name-server 10.0.0.2
dot11 syslog
dot11 activity-timeout unknown default 360
dot11 activity-timeout client default 360
dot11 ssid vhall-1
   vlan 1
   authentication open eap eap_methods
   authentication key-management wpa version 2
   guest-mode
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 1 mode ciphers aes-ccm tkip
ssid vhall-1
antenna gain 0
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid vhall-1
antenna gain 0
dfs band 3 block
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.0.0.251 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.7
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community bvilleprivate RO
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.0.0.2 auth-port 1645 acct-port 1646 key 7 132247420C00570D7B742F3F66
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
version 12.4
no service pad
hostname vhall-1
aaa new-model
dot11 syslog
dot11 ssid vhall-1
   vlan 1
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid vhall-1
antenna gain 0
station-role root
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
ssid vhall-1
antenna gain 0
dfs band 3 block
channel dfs
station-role root
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
end
I don't see anything obviously wrong. Have you looked at event viewer for the audit failure for when connecting to this AP?
HTH,
John
There are no audit failures, but each time I try to conenc to the device, the following error occurs:
Event Type: Error
Event Source: IAS
Event Category: None
Event ID: 18
Date:  12/14/2012
Time:  12:14:53 PM
User:  N/A
Computer: svr01
Description:
An Access-Request message was received from RADIUS client WAP-1 with a message authenticator attribute that is not valid.
I'm assuming that this might have to do with a certificiate? Will I have to generate a new cert for both new access points?
I had the same type issue with an older Dell switch. The switch was sending out a malformed packet, and I never got around it. Check to make sure that you have the same IOS version on both APs and, if not update the one that isn't working to the version of the one that is. Here's more information on the event code:
http://technet.microsoft.com/en-us/library/cc735343%28v=ws.10%29.aspx
HTH,
John
In this instance I think the ones that are not working actually have a newer IOS.
Try following this documentation to configure the new APs
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml
Hello again. Sorry for the long delay but I was in a accident and am finally back to work. I am able to connect w/ my network credentials but never get an ip from my dhcp server. I have a windows 7 sp1 laptop w/ my radius server cert installed. The laptop just sits on identifying and i never successfully get an IP. When i check my IAS logs they show authentication was successful. Any idea's?
