CISCO ASA 5505 two networks question
dpoynter01
I'm fairly new to cisco and the  ASA 5505 I have the asa connected to the internet on 0/0 I have a computer connected to port 1 and on port 2 I have a netgear router. the asa is 192.168.1.1 and the netgear router is 10.1.5.1  I cannot get the computer connected to the asa to communicate with the devices on the netgear router and visa versa. Here is the show version. any help would do! Thanks
ASA Version 8.0(4)
hostname ciscoasa
enable password Yn8Esq3NcXIHL35v encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-61551.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
router rip
passive-interface default
version 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username danpoynter password XEQ0M75K1B1E6VtM encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:5e0ff6f00d06109680e0a92ef06f345c
: end
Jeff Van Houten
Level 5
Level 5
The net gear and the Asa dont share a common subnet anywhere. You'll need something on the Asa to be in 10.x.y.z subnet the net gear is on.
