Cisco BL50R AUI to 10BaseT transceiver
andydenley
Hi Everybody!
I bought a AS2511RJ for my lab and a BL50R transceiver to allow my 2511 to access the LAN.
Now when I plug it with a Cat5e straight through cable from router A and configure a IP address on Ethernet0. I can see its receiving, but not sending. On the other side of the cable I have specified 10Mb/Half Duplex on the sending interface.
I have read the manual and can not find any information that may assist.
http://docstore.mik.ua/univercd/cc/td/doc/product/access/ap/ap_ts2/transc.pdf
Its has pretty lights on it that show it has a "link" and "Pwr" and sometimes "Rec" flashes to indicate it is taking traffic. But never send.
and a 'sh interface' shows
Ethernet0 is up, line protocol is down
  Hardware is Lance, address is 0050.5480.605b (bia 0050.5480.605b)
  Internet address is 172.16.99.253/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
     reliability 128/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Last input never, output 00:00:09, output hang never
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     139 packets output, 9096 bytes, 0 underruns
     139 output errors, 0 collisions, 7 interface resets
     140 lost carrier, 0 no carrier
is the AUI or transceiver faulty?
has any one seen this before?
Many thanks for any info.
Andy
Reza Sharifi
Most likely the problem is the AUI interface.  You can get a AUI on ebay for a very cheap price.
Reza Sharifi
Hi, the transceiver was faulty.
Glad to help and thanks for the rating.
