Cisco Broadcast & Multicast Storm Control
balbeer.singh84
I am going to configure the storm control in the switches & I am using the below commands :
interface <interface-list>
storm-control broadcast level 30.00
storm-control multicast level pps 5 3
I am applying this for all the access ports of the switches which are connecting to end users.
Please suggest whether I should apply this to uplink (trunk) ports of teh switches as well or not? If yes then what should be the limit on uplink (trunk) ports?
Please suggest.
-Balbeer
singhaam007
Level 3
Level 3
hello Balbeer,
you can use storm control config to control broadcast traffic.
Check this link for detail config
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22ea/SCG/swtrafc.html#wp1063295
hope fully this will help.
thanks
