Cisco Business 350 Series freezes when it starts
William ECG
Hello community.
When I turn on the switch, it freezes.
The reset button doesn't work.
By using the serial port I get the following output:
BootROM 1.41
Booting from SPI flash
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
mvCtrlPexPolaritySet: TWSI Write skipped, leaving PEX polarity in EP mode
PEX: pexIdx 0, detected no link
DDR3 Training Sequence - Ver TIP-1.57.0
mvSysEnvGetTopologyUpdateInfo: skipped Twsi read to enable DDR ECC update
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
Msys Booton: Sep 7 2021 00:40:16 ver 3.1.6
Secure Boot: ON
Press x to choose XMODEM...
Booting from NAND flash
Secure Boot: Verify U-Boot secure imageSecure Boot: getBootonSecureHeader
image sha256: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Verify secure U-Boot (1-1) pass
Running UBOOT...
U-Boot 2013.01 (Feb 13 2023 - 01:10:46) Version: armada-17.06.6 V3.2.1.22
NAND ID = 0xDA01
NAND Model = Cypress/Spansion 2Gb 8bit S34ML02G2
EZ1K secure board
CBS350-24T-4G
FPGA Version: 34.25
uboot sha256 calculated by booton: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Loading active image ...
image sha256: 509DD7D7CB484E70F4E90351FBD768F1B489D4F90F971F2DF38ED5A83E82C6B9
When using the serial port I get the following output:
I tried to upload a new firmware by the xmodem protocol but it didn't work.
Does anybody have any ideas about what can be done to repair it or any resources to solve the problem.
balaji.bandi
Try holding the reset button 30 seconds and see if that reset to factory.
BB
I tried, but it didn't work.
