Cisco Business CBS110-16PP
Coy091912
Hello
Hotel speed move up to 200 MBs recently and we got one sd wan with 14 static IP, I need to hook up two routers to this sd wan but only one port is enabled, I was requesting to the ISP to bridge a couple of ports so no need for me to get a new switch, the best they could do was to change the network from /28 to /29 on  a couple of ports, split the subnet, that means changing config, so I need a switch "unmanaged", one of the routers is for hotel wifi, and the second is for the PMS and office use, I was wondering if this Cisco Business CBS110-16PP its a good choice to use between the sd wan and the two routers, I'm choosing cisco looking for reliability, so would someone give an inside on this unmanaged switch
any help is really welcome
thank you
balaji.bandi
I am not user of these switches, as per the document seems to be good if you looking only Layer 2
you can also compare small business switches :
https://www.cisco.com/c/en_uk/solutions/small-business.html
BB
