Just making this post so no one else tries to run this software version on their 3850.
Do not attempt to run cat3k_caa-universalk9.16.12.01.SPA.bin on the 3850.
Mine is a C3850-12X48U-E.
I verified the SHA512 multiple times and even tried booting from a flash drive.
Currently SHA512 is: 5800720c79f217e150e50397006f199ceeb21e69721fd8a941b84c2675ec62666aa6a4b5aca58ed1079e470f6a3ceaa429e496279d409e47921aae8a90af48f2
Interface GE 0 link down***ERROR: PHY link is down Getting rest of image Reading full image into memory...Check base package header ...: done = 16384 Getting rest of image Reading full image into memory....done Reading full base package into memory...: done = 34200944 Bundle Image -------------------------------------- Kernel Address : 0x5342f3c0 Kernel Size : 0x43824e/4424270 Initramfs Address : 0x5386760e Initramfs Size : 0x1c0cf62/29413218 Compression Format: mzip Bootable image at @ ram:0x5342f3c0 Bootable image segment 0 address range [0x81100000, 0x81da5280] is in range [0x80180000, 0x90000000]. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377 Loading Linux kernel with entry point 0x81894d40 ... Bootloader: Done loading app on core_mask: 0x3f ### Launching Linux Kernel (flags = 0x5) Linux version 4.9.177 (xelinux@sjc-xelinux1) (gcc version 5.3.0 (GCC) ) #1 SMP Fri Jun 7 18:13:03 PDT 2019 CVMSEG size: 2 cache lines (256 bytes) Cavium Inc. SDK-5.1.0 bootconsole [early0] enabled CPU0 revision is: 000d900a (Cavium Octeon II) Checking for the multiply/shift bug... no. Checking for the daddiu bug... no. Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
have you read the release notes.
More intrested to learn from what version you try to upgrade :
Yes, I always read the release notes for known issues and even noticed the installation command changed slightly, telling you to put "new" at the end of "req platform software package install sw all file...".
I was attempting an upgrade from Fuji-16.9.3a MD (cat3k_caa-universalk9.16.09.03a.SPA.bin).
I don't think that really matters much (unless older versions used an older ROMMON) because I even tried booting from a flash drive in ROMMON.
Also, if you google the actual error:
I believe this means the Kernel wasn't configured correctly.
Good to know you are in right direction, if this is not in production and you have not seen any outage.
try Gib 16.11.X and upgrade to 12.X
It was in production and caused some downtime but for me it's not a huge problem.
Just warning other people.
The only Gibraltar release I can see for the C3850 is this one: cat3k_caa-universalk9.16.12.01.SPA.bin
since its new release as value added for others and TAC benift raise TAC case so they make a note allow them to do test and realse fix for you.
NOTE ; iam going to do upgrade same verison 11.X or 12.X on Cat 9500 and let you know outcome.
I don't have a support contract so all I can do is post here.
Since my new thread keeps getting flagged as spam, I'll reply to this post.
Gibraltar-16.12.4 MD (cat3k_caa-universalk9.16.12.04.SPA.bin) has the exact same issue.
So either I'm extremely unlucky or Gibraltar just doesn't work on the C3850 platform.
Be warned.
Post the entire boot-up process so we can have a look.
NOTE: I have a few 3850 running 16.12.4 and no issue like this in production.
It's the exact same error as above.
I posted a new thread with the console output but it never got published because it was marked as spam.
The output was pretty much identical to the above.
When I put the BIN file on a USB stick and hold the mode button to bypass startup then type boot usbflash0:/file.bin it still fails with the same error.
