Cisco C1000-48P-4X-L not booting after reset
alimurtazo
I hstacked 4 Cisco C1000-48P-4X-L switches for testing. Then, trying to use them separately, I reset one of them through boot mode. After that I put the config on the switch. When I unplugged the power and plugged it back in, the switch wouldn't boot. I changed the IOS version of the switch, I also installed the latest one. But it didn't help. It gives the following error.
Front-end Microcode IMG MGR: Programming device 0...
IMG MGR I2C write failedError : Not able to send packet sizew
% Front-end Microcode IMG MGR: address 0, failed to switch to bootloader mode.
% Front-end Microcode IMG MGR: unable to program device
RE Msg payload send failed
INIT: Pp init completed.
INIT: ASIC 0 phases init completed.
INIT: ASIC 1 phases init completed.
INIT: phases init completed.
INIT: features init completed.
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
**RE Polling Disabled***
Waiting for Stack Master Election...
POST: Thermal Tests : Begin
POST: Thermal Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Initializing Device Manager...
Waiting for Port download...Complete
rem_i2c_get_reply: Reached max retries in getting reply
marce1000
    - That looks like a hardware error ; try full power cycle and or cold start too , if not yet done.
                                                          -> attach a console first , then look at the self test sequences during power on ,
 M.
I did it. But it didn't help.
I found the following difference behind failed switch with normal switch loading. But I couldn't figure out what these functions are responsible for and how to fix it. Both switches have same IOS and same model.
Normal switch boot Failed switch boot
Boot Loader upgrade not needed(v)
PCI-e 0: Detected Link.
PCI-e 0: (bus 0) , Detected Link X1, GEN 2.0
MCU version 0x17
Unable to send version command to MCU
Current MCU BL version 0xAE
Unable to send BL version to MCU
Checking for MCU firmware upgrade..
 New version = 0x17
 New version = 0x17
 Current version = 0x17
 Current version = 0x0
MCU Upgrade not needed!!
       - The device is broken and needs to be replaced (RMA) ,
 M.
