Cisco C1111-8P (1RU) and IPSec - VPN
amh4y0001
Level 3
Level 3
IPSec VPN is supported for the Cisco C1111-8P (1RU) running System image file is "bootflash:c1100-universalk9_ias.16.09.04.SPA.bin"?
If yes, will appreciate a step-by-step guide for the purpose of Site-to-Site VPN configuration?
as per show version you have ipbase, you need get security License to work for VPN.
BB
5 Replies 5
amh4y0001
Level 3
Level 3
Thanks for reply Balaji.
This means this Router do support VPN but needs special license. If I am not mistaken, it is special IOS image you meant?
How I can check if my device has correct license?
Also, there is no indicator of the VPN on the front panel (like an LED that shows if VPN is configured /operational), is this normal?
show license feature
show version
BB
Thanks for reply, see attached output for both commands.
BB
