C9200-48P network module C9200-NM-4X disappear
Clem58
Level 3
Level 3
Hi all
We have 3 C9200-48P stacked switches, with SFP+ network modules C9200-NM-4X on each.
We have observed the Te1/1/x ports have disappeared from the interfaces list.
Is the network module C9200-NM-4X hot swappable ? Can we try to remove it then re-insert it while the switch is running, in order to see the Te ports re-appearing ?
5 Replies 5
Seb Rupik
Hi there,
Is there anything in the logs to suggest the network module has been removed?
Yes, the Network Module is hot-swappable and can be removed/ inserted whilst the switch is powered on.
cheers,
Seb.
Unfortunately, the logs is too recent to see anything.
Thanks for your help Seb.
balaji.bandi
yes they are hotswappble, but suggest to do this in maintenance window always.
BB
Sure, we'll do. Thanks Balaji.
Also try to capute logs see if you can see any obnormal ?
BB
