03-16-2015 04:33 AM - edited 03-07-2019 11:06 PM
Hello!
I have a issue with my C2960S (2 pieces stacked). There's a huge amount of total drops on high load ports.
Example:
sw1-tix#show interfaces gi1/0/10
GigabitEthernet1/0/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is a456.309b.1f8a (bia a456.309b.1f8a)
Description: webcache.tix:eth0
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 5/255, rxload 18/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 3d01h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 190169
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 72305000 bits/sec, 6748 packets/sec
5 minute output rate 20782000 bits/sec, 5426 packets/sec
1221960223 packets input, 1628563836169 bytes, 0 no buffer
Received 528 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
979698245 packets output, 475525598184 bytes, 0 underruns
sw1-tix#show platform port-asic stats drop Gi1/0/10
Interface Gi1/0/10 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 10369171
Queue 4
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 5
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 6
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 7
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
There are multiple ports having the same issue that have huge bandwidth load. There are 15 ports that drop packets on both SW1 & SW2.
QoS is disabled.
sw1-tix#show mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
Queueing:
sw1-tix#show queueing interface GigabitEthernet 1/0/10
Interface GigabitEthernet1/0/10 queueing strategy: none
What more should I debug? Having a huge problem here.
03-16-2015 05:39 AM
What is connected to the ports that drop packets?
03-16-2015 05:52 AM
A IBM server that holds memcache for webservers. Basically its a cache server that caches most of the data so sql server does not get big loads.
Its only one example. Our blade center port-channel drops a lot more data. Its running web nodes etc etc etc.
sw1-tix#show interfaces Po2
Port-channel2 is up, line protocol is up (connected)
Hardware is EtherChannel, address is a456.309b.1f84 (bia a456.309b.1f84)
Description: sw1<->sw2-bc1
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 36/255, rxload 13/255
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
Members in this channel: Gi1/0/4 Gi2/0/4
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d02h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 11320197
5 minute input rate 105486000 bits/sec, 29763 packets/sec
5 minute output rate 288741000 bits/sec, 38110 packets/sec
5988485517 packets input, 2527858009372 bytes, 0 no buffer
Received 782441 broadcasts (295185 multicasts)
0 watchdog, 295185 multicast, 0 pause input
8222989007 packets output, 8901793764050 bytes, 0 underruns
