03-13-2015 07:29 AM - edited 03-07-2019 11:04 PM
When I try to move port channel connections to two of the SFP ports on our Cisco 2960S switch, one of the connections fail.
I am using two GBics, both are the same, GLC-T-A 1000Base-T.
The port channel work fine when I use g1/0/47 and 48.
The port channel work fine when using g1/0/48 and SFP 1/0/49
Port channel does not work when using SFP 1/0/49 and SFP 1/0/50.
03-13-2015 09:51 AM
What is the error message you get?
When this happens, what does the log show?
What version of IOS are you running?
03-16-2015 06:01 AM
Cisco C2960S software version: 12.2(55)SE7. Using C2960S-UNIVERSALK9-M.
Port configurations for g1/0/48 - 51:
interface GigabitEthernet1/0/49
description Trunk to Cisco Core
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
macro description cisco-switch
auto qos trust
spanning-tree link-type point-to-point
channel-group 2 mode on
When working, both ports show green status lights.
ort Name Status Vlan Duplex Speed Type
Po2 Trunk to Core connected trunk a-full a-1000
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* Port-channel2 0 0 0 0 8390000 909 970000 551 0
Age of the Port-channel = 0d:10h:57m:35s
Logical slot/port = 5/2 Number of ports = 2
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = -
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi1/0/47 On 0
0 00 Gi1/0/49 On 0
When not working, one port shows green, then other port status light is off.
GigabitEthernet1/0/49 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 3c0e.233f.a531 (bia 3c0e.233f.a531)
Description: Trunk to Cisco Core
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:09, output 00:00:19, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1954000 bits/sec, 213 packets/sec
5 minute output rate 38000 bits/sec, 16 packets/sec
2935639 packets input, 880524431 bytes, 0 no buffer
Received 2211794 broadcasts (310067 multicasts)
0 watchdog, 310067 multicast, 0 pause input
370489 packets output, 66729219 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
GigabitEthernet1/0/50 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 3c0e.233f.a532 (bia 3c0e.233f.a532)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
--More-- 0 output errors, 0 collisions, 1 interface resets
Let me know if you need more info.
03-13-2015 12:58 PM
Tony, we need more details like Reza mentioned.
the Port config of both switches, the logs...I nerver faced that issue..
03-13-2015 11:50 PM
Hi Tony,
Please share more details. Is problem only with 1/0/50 not being able to add to bundle?
Please share config, log message etc to check
M
