CISCO C3750E CPU utilization 100%
nishhhant
Dear Team,
I am experiencing an issue with my core switch C3750E (L3 switch) with the cpu utilization going 100% and in cpu processes I see the ARP input is using more than 61% of the cpu.
CPU utilization for five seconds: 99%/25%; one minute: 99%; five minutes: 99%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  12  1313789569    66834997      19657 60.10% 61.13% 61.48%   0 ARP Input
  85    75586512    18520293       4081  1.76%  1.46%  1.44%   0 RedEarth Tx Mana
  84    27740856    23022207       1204  1.44%  1.00%  0.94%   0 RedEarth I2C dri
214    51056595   110992559        460  1.28%  1.65%  1.64%   0 IP Input
129    26284746     4806428       5468  0.96%  0.83%  0.82%   0 hpm counter proc
Please suggest what I can provide from my end from show run and help me out resolving this issue.
Warm Regards,
Nishant.
25 Replies 25
Do you want me to downgrade the IOS version from 12.2(58)SE2 to 12.2(55)SE8 ?
My recommendation is for you to downgrade to 12.2(55)SE8.
Do you have any other suggestion of resolving this issue ...
Aside from downgrading the IOS?  Sure, create a Cisco TAC Case.
Hi Leo,
Lol I could have raised a Cisco TAC but my switch is out of warranty..
The entire 12.2(58)SE train is very buggy.  I've used this version before and downgraded all of my 3560/3750 fleet to 12.2(55)SE8.
Hi Nishant,
Are the hosts on your network not under the management of you IT services group? I would locate the offending machine and talk with the owner about why it is trying to contact so many hosts on the network. If it can't be explained then disconnect it from the network until they can.
This is the sort of behavior you might expect from a machine riddled with viruses!
cheers,
Seb.
Hi Seb,
The hosts not in management vlan but they have full access to internet through proxy.
There are around 325 users in this vlan that is 142 where most of all the hosts trying to reach the few hosts which are not in the network. Due to which ARP entries are incomplete.
What is the 'ip route' config on this switch?
If you are specifiying the next-hop as an interface and not an IP then the switch will generate an ARP request for every packet which it does not have a more specfic route.
Hi Seb,
Please find the show ip route output below :-
D*EX  0.0.0.0/0 [170/28416] via 192.168.24.137, 1d15h, GigabitEthernet1/0/24
      10.0.0.0/8 is variably subnetted, 7 subnets, 4 masks
S        10.70.4.0/23 [1/0] via 192.168.24.158
S        10.70.6.0/24 [1/0] via 192.168.24.158
S        10.70.56.0/21 [1/0] via 192.168.24.158
S        10.70.66.0/23 [1/0] via 192.168.24.162
C        10.70.68.0/23 is directly connected, Vlan207
L        10.70.68.2/32 is directly connected, Vlan207
S        10.70.70.0/23 [1/0] via 192.168.24.174
      192.168.24.0/24 is variably subnetted, 11 subnets, 2 masks
C        192.168.24.136/30 is directly connected, GigabitEthernet1/0/24
L        192.168.24.138/32 is directly connected, GigabitEthernet1/0/24
D        192.168.24.140/30 [90/28416] via 192.168.150.3, 6d12h, Vlan150
                           [90/28416] via 192.168.149.3, 6d12h, Vlan149
                           [90/28416] via 192.168.24.137, 6d12h, GigabitEthernet1/0/24
                           [90/28416] via 10.70.68.3, 6d12h, Vlan207
C        192.168.24.156/30 is directly connected, GigabitEthernet1/0/21
L        192.168.24.157/32 is directly connected, GigabitEthernet1/0/21
C        192.168.24.160/30 is directly connected, GigabitEthernet1/0/18
L        192.168.24.161/32 is directly connected, GigabitEthernet1/0/18
C        192.168.24.168/30 is directly connected, GigabitEthernet1/0/1
L        192.168.24.169/32 is directly connected, GigabitEthernet1/0/1
C        192.168.24.172/30 is directly connected, GigabitEthernet1/0/16
L        192.168.24.173/32 is directly connected, GigabitEthernet1/0/16
S     192.168.135.0/24 [1/0] via 192.168.24.158
S     192.168.136.0/22 [1/0] via 192.168.24.158
S     192.168.140.0/23 [1/0] via 192.168.24.162
C     192.168.142.0/23 is directly connected, Vlan142
      192.168.142.0/32 is subnetted, 1 subnets
L        192.168.142.2 is directly connected, Vlan142
S     192.168.144.0/23 [1/0] via 192.168.24.174
      192.168.146.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.146.0/24 is directly connected, Vlan146
L        192.168.146.1/32 is directly connected, Vlan146
      192.168.147.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.147.0/24 is directly connected, Vlan147
L        192.168.147.1/32 is directly connected, Vlan147
      192.168.148.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.148.0/24 is directly connected, Vlan148
L        192.168.148.1/32 is directly connected, Vlan148
      192.168.149.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.149.0/24 is directly connected, Vlan149
L        192.168.149.2/32 is directly connected, Vlan149
      192.168.150.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.150.0/24 is directly connected, Vlan150
L        192.168.150.2/32 is directly connected, Vlan150
      192.168.151.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.151.0/24 is directly connected, Vlan151
L        192.168.151.2/32 is directly connected, Vlan151
      192.168.152.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.152.0/24 is directly connected, Vlan152
L        192.168.152.1/32 is directly connected, Vlan152
Hi Seb,
When you specify IP for a route you have to specify for all segments on the switch...which in turn will increase the processes on the switch and the table length will increase the cpu of switch..so we are working on how to restrict unwanted arp request..If you can provide a resolution to restrict please let me know
Cheers,
Nishant.
For the time being I have managed to minimize the utilization.
Now its as below "-
show proc cpu sorted | in ARP
  12  1461177163    88623776      16487 14.07% 16.87% 19.47%   0 ARP Input
  13      232156     4977278         46  0.00%  0.00%  0.00%   0 ARP Background
  41     2791625     4801887        581  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  40     8083154     6113999       1322  0.00%  0.00%  0.00%   0 ARP Snoop
212      449891      127484       3528  0.00%  0.00%  0.00%   0 IP ARP Adjacency
213      731410   109891119          6  0.00%  0.00%  0.00%   0 IP ARP Retry Age
216      164817     9172622         17  0.00%  0.00%  0.00%   0 IP ARP Track
277       15835      503671         31  0.00%  0.00%  0.00%   0 Cluster RARP
285           0          12          0  0.00%  0.00%  0.00%   0 RARP Input
show arp | in Incomplete
Internet  192.168.142.147         0   Incomplete      ARPA
Internet  192.168.142.193         0   Incomplete      ARPA
Internet  192.168.149.23          0   Incomplete      ARPA
show proc cpu | in CPU
CPU utilization for five seconds: 42%/14%; one minute: 41%; five minutes: 46%
