Bookmark
Subscribe
387
Cisco C3750G Power On Failure
AvidPontoon1
I have been using my C3750G for a while now. It has been used normally and hasn't been exposed to any excess heat but for some reason when I issued the 'reload' command the other day the switch didn't start back up. Instead all of the indicator/status lights came on that are on the front, excluding the port link lights. Some were green and others orange. I left the switch for half an hour and the lights were still on. The switch wouldn't boot, and nothing on the serial.
Now, after this event to get the switch to boot, I have to plug into power and it will do the same thing and not boot. Other times it will boot properly. How can this be? I have upgraded the IOS on it today but it's no different. It is luck if the thing will boot or not. Sometimes this can be up to 10 times plugging into power and then disconnection and retrying.
Please can someone tell me what is wrong with my switch?
Leo Laohoo
Most likely it's dead. Contact Cisco TAC and get the appliance RMA-ed.
The switch is seccond hand. So I cannot contact Cisco and get it retuened. I guess I will have to live with it not booting every so often. The switch stays on nearly all the time so there is never a reason that I should have to pull power from it. For this reason I will just have to get an new one.
