Nexus 7010 to Nexus 9508 ACL workaround
thomuff
Level 3
Level 3
We plan on replacing our Nexus 7010 with a Nexus 9508
One challenge is that the Nexus 9508 does not support IPv4 ACL on Egress of the SVI
One solution is remove the VLAN interface and route to the traffic to a Firewall .
We are looking for other solutions
The purpose of the ACL is to limit traffic destined to the VLAN devices.
A restrictive vlan.
Reza Sharifi
How do you limit the traffic today using 7010?
If it is qos, firewalls may have more limited functionalities when it comes to QOS.
We limit the traffic to day with an IPv4 ACL applies to the VLAN interface
Ie
Int vlan 23
ip access-group LIMITACCESSOUT out
This command is not supported on the Catalyst 9508
Another suggestion was a VACL.
VACL is used for blocking and forwarding within a vlan and not inbound or outbound to a vlan.
You did not post the ACL statement but if you have a deny statement, this will block all traffic and not limit traffic.  Is that what you are trying to do?
by removing the logging option in the acl, we were able to apply the ACL
The posts were very helpful.
