03-22-2024 10:52 PM
So I bought a C9300-24UX-A for my homelab (not new). It came with a C9300-NM-4G and I also bought a C9300-NM-2Y (dual sfp28) however I cannot get either module to show up in suing "show inventory" and the 25gb module does not ever get a link with the network card.
Anyone have some troubleshooting steps before I ask the seller for a replacement to try getting it working?
I have tried updating the IOS version to latest and latest recommended and neither work, power cycling, inserting/reinserting to no avail so far.
03-23-2024 03:03 AM
Personally installed many modules NM-2Y I have not come across any issue.
Make sure the Modules correctly inserted and not wrong threaded - which causes the socket broken.
Turn Off the switch - Remove the Module and re-insert again, connect console and post complete boot log for us to review.
based on that information - it straight forward installation module . until hardware gone failed.
=====️ Preenayamo Vasudevam ️=====
03-23-2024 03:58 AM
- Some modules types can have a status led , so that an OK status (green e.g.) can be observed when a module is inserted (as stated not always available)
M.
03-23-2024 05:45 AM
Connect to your switch via the console port, or telnet/ssh into it and issue the enable command terminal monitor to see log messages, and insert the module. Is there any messages that are displayed by the switch in the terminal? Share them here.
