Cisco C9300 stack compatibilty C9300-48U-A-UL with C9300-48P
Abderahman-K
Looking for information whether or not a C9300-48U-A-UL switch can be stacked with C9300-48P?
the C9300-48U-A-UL is a UL1069 Standard compatible switch if it matters
I see. The part number you posted (C9300-48U-A-UL) is not part of the "UB" family and so, you should be able to stack it together with C9300-48P-A, because the only difference between the 2 is that one comes with UPOE (60W) and the other one is just regular POE+ (30W). My apologies.
Reza Sharifi
No. that is not supported:
Mixed stacking between Catalyst 9300 and Catalyst 9300X and Catalyst 9300 higher scale models (C9300-24UB, C9300-24UXB, C9300-48UB) is not supported. You cannot stack fixed uplink models (C9300L SKUs) with modular uplink models (C9300 SKUs) or other Catalyst switches, e.g. Cisco Catalyst 3850 and 3650 Series. Any combination of Catalyst 9300 models can form a stack. Separately, any combination of Catalyst 9300L models can form a stack.
link for more info:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
Thanks, Reza,
Thanks for the link, but looks like the C9300-48U-A-UL is not from the C9300L family, it's the same family as the C9300-48P. so shouldn't they be compatible with each other?
Am I correct in my interpretation?
C9300-48P-A
Catalyst 9300 48-port 1G copper with modular uplinks, PoE+, Network Advantage
C9300-48U-A-UL
Catalyst 9300 48-port 1G copper with modular uplinks, UPOE, Network Advantage
(Compatible with UL1069 Standard*)
