Cisco C9500-40X platform stuck in Boot when powered on
MickeyMc
Cisco C9500-40X platform stuck in Boot when powered on Ctrl C does not allow to interupt the boot. Holding the mode button whilst powering until the blue led flashes on does not work either. Any ideas please?
Initializing Hardware......
System Bootstrap, Version 17.8.1r[FC2], RELEASE SOFTWARE (P)
Compiled Thu 02/24/2022 22:45:03.07 by rel
Current ROMMON image : Primary
Last reset cause     : PowerOn
C9500-40X platform with 16777216 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
better open  a TAC
Good luck
KB
better open  a TAC
Good luck
KB
marce1000
              - FYIhttps://bst.cisco.com/bugsearch/bug/CSCvo21693
                        https://bst.cisco.com/bugsearch/bug/CSCvm11474
 M.
 M.
Leo Laohoo
If the switch is in ROMMON, post the complete output to the following commands:
  1. dir flash:
  2. set
jmatty520
Just to add another experience, I had this exact same problem, but after pulling the power and plugging it back in, it booted up fine. Then I made sure the boot statement was set correctly.
