Cisco catalyst 1300 - VTP Domain and VTP Mode Client
I purchased a Catalyst 1300. I configured the Mgt Vlan and connected the port in trunk. I would like to set the VTP Domain and the VTP Mode Client so as to be able to associate the vlans of my Cisco 9300 (Switch l3) on the interfaces. Can you give me the CLI commands? Thank you
Torbjørn
The C1300 runs the same OS as the CBS series switches. It unfortunately does not support VTP.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
https://journey2theccie.wordpress.com/2020/05/11/vtp-version-3-configuration/
but to see the effect of your config you need two SW at least
MHM
In the Cisco catalyst 1300 switch I did not find VTP commands. I'll paste the "sh?" . While in the catalyst 1000 the vtp commands exist calmly. I need to know how to set the VTP Domain on the Catalyst 1300 switch that I purchased a few days ago.
SW-C1300-LAB-QUA#sh vtp status
% Unrecognized command
SW-C1300-LAB-QUA#
Torbjørn
Thank you for your answer. I looked into it further. Actually the switch does not support vtp. The switch is in transparent mode. Okay. I will configure the vlans on the switch. Thank you
