Cisco catalyst 2950 problem
blue4cisco
Level 3
Level 3
We have cisco 2950 catalyst switch .we hv 1 MBps internet connection through modem comming into catalyst switch 2950.but after some time running ok port light gets orange & we loose connectivity.but it runs on 128 kpbs ok. switch is not configure.what is problem ?
Georg Pauwen
do you see any errors on the port of the 2950 where the modem is connected to ? Can you post the output of 'show interfaces FastEthernet' of the port in question ?
GP
amit-singh
Level 11
Level 11
Seema to be a auto-negotiation issue. Check whether the device connected to switch port supports which speed 10/100 and also the duplex full/half. Try to Hardset the speed and duplex on the switch port and the other device port,
regards,
-amit singh
handsomeamit1
Community Member
which modem you are using pls specify the make and model also paste in the config of your switch.
