IP INSPECT Problems
dukenukem
Hi All,
I would like some light into the weird behaviour of IP INSPECT.
Here is my setup:
I have 3 sites, each having its own Router
Site A cisco 1721
Site B cisco 3745
Cite C cisco 1721
B is the main Router and A and C are connected to it with FR-ATM such as i am showing in the attached document
Please Note that the 3745 is connected to the other sites with ATM subinterfaces.
I have inherited this configuration, and i am sure that the IP Inspect statements are a bit messy.
There are ACLs applied IN and OUT on the internet interface (obviously for protection) and also the IP INSPECT STOP OUT Statement .which says :
ip inspect name STOP tcp
ip inspect name STOP ftp
ip inspect name STOP h323
ip inspect name STOP rcmd
ip inspect name STOP netshow
ip inspect name STOP realaudio
ip inspect name STOP rtsp
ip inspect name STOP sqlnet
ip inspect name STOP streamworks
ip inspect name STOP tftp
ip inspect name STOP udp
ip inspect name STOP vdolive
ip inspect name STOP smtp
ip audit notify log
ip audit po max-events 100
The ACL that is APPLIED INWARDS is:
ip access-list extended IN_ACL
permit tcp host 10.189.31.61 host 10.189.10.114
permit tcp host 10.189.31.61 host 10.51.22.6
permit udp host 10.189.10.113 host 10.189.10.114 eq isakmp
permit ahp host 10.189.10.113 host 10.189.10.114
permit esp host 10.189.10.113 host 10.189.10.114
permit icmp host 10.189.10.113 host 10.189.10.114
permit tcp host 10.189.51.23 host 10.51.11.2 eq 7777
permit tcp host 10.189.51.23 host 10.51.11.2 eq 4443
deny ip any any
THE ACL applied OUTWARDS is
ip access-list extended OUT_ACL
permit tcp host 10.51.22.6 eq telnet host 10.189.31.61
permit tcp host 10.51.11.2 eq 4443 host 10.189.51.23
permit tcp host 10.51.22.6 host 10.189.31.147 eq www
permit tcp host 10.51.22.6 host 10.189.31.148 eq www
permit tcp host 10.51.22.6 host 10.189.31.131 eq www
permit tcp host 10.51.22.6 host 10.189.31.132 eq www
permit tcp host 10.51.22.6 host 10.189.31.99 eq www
permit tcp host 10.51.22.6 host 10.189.31.115 eq www
permit tcp host 10.51.22.6 host 10.189.31.116 eq www
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.115 eq pop3
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.116 eq pop3
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.115 eq smtp
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.116 eq smtp
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.195 eq ftp
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.195 eq ftp-data
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.115 eq 389
permit tcp 10.51.0.0 0.0.255.255 host 10.189.31.116 eq 389
permit udp 10.51.0.0 0.0.255.255 host 10.189.31.163 eq domain
permit tcp host 10.51.22.131 host 10.189.31.83 eq 1352
permit tcp host 10.51.22.131 host 10.189.31.84 eq 1352
permit tcp host 10.51.22.137 host 10.189.31.83 eq 1352
permit tcp host 10.51.22.137 host 10.189.31.84 eq 1352
deny ip any any
With the current Setup we had all sorts of weird things going on (not working i mean)
The only way to get things to work normally is to apply an IP INSPECT STOP OUT on every ATM subinterface on the 3745 router, and also apply IP INSPECT STOP OUT on the LAN of the 3745.
By doing this, i can get things to work.
One thing that does not work is trying to access a server using UNC Path (\\servername )or even (\\IP_Address )located at Site C LAN from a PC at Site A (no ACLs or IP INSPECTS are applied on site A and C routers)
From Lan B to Server on LAN C is working
From Server on LAN C to machines on LAN B or LAN A is working.
If i remove the IP INSPECT commands, on the Site A and Side B ATM subints UNC works properly, but then Remote Desktop does not work.
What i would like to know is how IP inspect is affecting this and a value from 0 to 10 how effective this IP INSPECT Configuration is (I believe is 0 )
I hope i did not bore you.
Hope u can help me out.
George
b.hsu
Level 11
Level 11
Perform these steps to configure firewall inspection rules for all TCP and UDP traffic, as well as specific application protocols as defined by the security policy, beginning in global configuration mode:
http://www.cisco.com/en/US/products/ps5853/products_configuration_guide_chapter09186a0080458303.html
