Cisco Catalyst 2950
paul dungey
Good Morning,
I'm having a few issues with a Cisco Catalyst 2950 48 port Switch where by i'm trying to access the system, ( Note I've ommited customer identifying information with Astrix )
I've followed the password recover procedure and set the password to each login level from the link below, when the  switch rebooted it still displayed the message below, prior to this ive  reset the passwords on the follwoing levels
Secret,
Enable password
Line VTY 0 15
Line con 0
http://www.cisco.com/image/gif/paws/12040/pswdrec_2900xl.pdf
The information below has been taken from the switch all passwords have been reset, once switch has been rebooted I'm still getting the motd banner and login:
I've rebooted the unit again and rerun the commands of
Flash_init
load_helper
boot
but i'm still getting the same message below and not quite sure where to goto from here
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    load_helper
    boot
switch: flash_init
Initializing Flash...
flashfs[0]: 409 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4909056
flashfs[0]: Bytes available: 2832384
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
switch: load_helper
switch: boot
Loading
"flash:/c2950-i6q4l2-mz.121-22.EA8.bin"...###########################################################################################################################################################
File "flash:/c2950-i6q4l2-mz.121-22.EA8.bin" uncompressed and installed, entry oint: 0x80010000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA8, RELEASE SOFTWARE(fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 12-May-06 17:19 by myl
Image text-base: 0x80010000, data-base: 0x8056A000
Initializing flashfs...
flashfs[1]: 409 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4909056
flashfs[1]: Bytes available: 2832384
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
POST: FRONT-END LOOPBACK TEST : Passedcisco WS-C2950SX-48-SI (RC32300) processo (revision M0) with 21004K bytes of memory.
Processor board ID FOC1034Z076
Last reset from system-reset
Running Standard Image
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:19:2F:6D:B2:00
Motherboard assembly number: 73-9103-05
Power supply part number: 34-0965-01
Motherboard serial number: FOC1033567L
Power supply serial number: DTH10233CMH
Model revision number: M0
Motherboard revision number: A0
Model number: WS-C2950SX-48-SI
System serial number: FOC1034Z076
CLEI Code Number: CNMRY002RA
Top Assembly Part Number: 800-24115-04
Top Assembly Revision Number: A0
Version ID: N/A
Cannot open logging port t0 ****************
Press RETURN to get started!
000048: *Mar  1 00:00:29 UTC: %IP_SNMP-3-SOCKET: can't open UDP socket
          *** ONLY PROCEED IF YOU ARE AN AUTHORISED USER **
   This is an official computer system and is the property of the
   ***********************************. It is for authorised users only.
   Unauthorised users are prohibited. Users (authorised or unauthorised)
   have no explicit or implicit expectation of privacy. Any or all uses of
   this system may be subject to one or more of the following actions:
   interception, monitoring, recording, auditing, inspection and disclosing
   to security personnel or law enforcement personnel, as well as authorised
   officials of other agencies, both domestic and foreign. By using this
   system, the user consents to these actions. Unauthorised or improper use
   of this system may result in administrative disciplinary action and civil
   and criminal penalties. By accessing this system you indicate your
   awareness of and consent to these terms and conditions of use. Discontinue
   access immediately if you do not agree to the conditions stated in this
   notice.
User Access Verification
Username:
Paul
Ivan Shirshin
Hi Paul,
You forgot to rename the config file to some other name so that system won't boot it.
After the "load_helper" run the "dir flash:". You should see config.text file there. Rename it with the following command "rename flash:config.text flash:config.old" to other file name and after that run "boot".
Switch should boot in initial config prompt now. Say "no" and restore configuration:
     rename flash:config.old flash:config.text
     copy flash:config.text system:running-config
Finally, change the passwords and vty auth and save configuration to flash with "wr".
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Hi Paul,
Kind Regards,
Ivan
Kind Regards,
Ivan
I Ivan
I've now managed to get access to the switch and have removed the client information from VLAN and all IP configuration,
many thanks for you support
kind Regards
Paul Dungey
Glad to hear that, Paul! and thanks for rating
Kind Regards,
Ivan
